Nice! Do you happen to have a SAK around to post for a size comparison?
91mm SAK. 2 layer. (Image removed from quote.)(Image removed from quote.)
Thanks! Looks like you have a favorite blade shape.
You fooled me for a second. Awesome blade shape!
... excellent looking mod Sam I'd like a plain edge version with bit exchanger instead of big flat driver please
Nice work To start with I thought it was a factory model. Love the blade shape
Plain edge probably at some point of time. I tried a few combination for the internal tools. There's 2 spring bars. Each is appx the same thickness as a normal tool on the Wave. That would also means I can only have a bit adapter in there.. I did tried that before but because the whole tool is pretty small so it's difficult to use as a proper screwdriver. Light use fine though. I didn't want to use a Skeletool handle as I prefer the curved shape at the end. And the end of the skeletool is not pointing straight, it will be a little awkward to turn.
I actually went to the website to look for it
It's not there anymore?
As usual your mods are incredible! I used a skeletool CX to do something similar using a wingman clip, but this is way way better!(Image removed from quote.)mine wasn't too comfortable. yours looks much much nicer.
I was playing around with other blade profiles. The plain edge was from another previous mod that's why the spine looks weird.. But it is a good piercer and slices great. (Image removed from quote.)
I was lucky I had a kbx lying around. does the holes on the Skele align with the wingman's clip? That's pretty awesome!
As usual your mods are incredible! I used a skeletool CX to do something similar using a wingman clip, but this is way way better!mine wasn't too comfortable. yours looks much much nicer.
