FS: SOG Powerlock and bit set UK
Offline riddoch
on: April 28, 2020, 04:17:54 PM
Just gotten a new leatherman so need to reduce the number of multitools i seem to have collected. The SOG Powerlock multitool has 18 tools. The hinge of the pliers is geared so you can put more force on the pliers, SOG has named this Compound Leverage. This also allows for one handed opening of the pliers which is handy.
Looking for £65 posted in the UK
The 1/4 “driver on this tool is very convenient because you can use the 1/4″ connection with the extra bits for torx and hex as well.
The SOG Powerlock  comes with a leather pouch and 1/4” socket converter and bits.
Tools
Blade (partially serrated)
Pick
1/4 “driver for wrench Sockets
File (3-sided)
Scissors actually box cutter, teach me for copying a description from another site.
Wood saw
Needle-nose pliers
Regular pliers
Thread cutter
Wire stripper
Ruler (inch and cm)
Clamping pliers
Can opener
Bottle opener
Small screwdriver
Medium screwdriver
Large screwdriver
Phillips screwdriver
Hardness: 51-53 HRC
« Last Edit: April 28, 2020, 05:42:03 PM by riddoch »
gb Offline tosh
Re: FS: SOG Powerlock and bit set UK
Reply #1 on: April 28, 2020, 05:31:31 PM
I’m interested in buying
But can’t see the scissors in the picture - yet listed in description?
If it has scissors I’m definitely interested.
You don’t state the condition?
Chips, twisted head??
Offline riddoch
Reply #2 on: April 28, 2020, 05:39:29 PM
Hi,
I would say it's in good condition with no obvious damage.
You are right there is no scissors, I pulled the description off a site selling new ones and didn't spot that.
Cheers
Neil
gb Offline tosh
Reply #3 on: April 28, 2020, 06:17:03 PM
Hi,
Cheers
Neil
Ah’ thanks for confirming Neil
I’ll let someone else give it a home. The scissor variant seems a little harder to find in the UK
I just picked up 2 SOG display cases - hence being interested in yours BUT with scissors.
Not to worry
Best of luck
Offline Leathermanluva
Reply #4 on: April 28, 2020, 07:00:27 PM
Hello, you have PM
Offline riddoch
Reply #5 on: April 28, 2020, 07:48:38 PM
Hi,
I've not made enough post to reply. The idea is reduce the amount of things I have but I will consider it, can you send a pic :D.
Cheers
Neil
Reply #6 on: April 28, 2020, 09:05:25 PM
Haha yeah I will reply now
November Goal: $300.00
Due Date: Nov 30
Total Receipts: $72.17
PayPal Fees: $4.65
Net Balance: $67.52
Below Goal: $232.48
23%
November Donations
