Which is better for staying up with things as far as keeping up with times ?
8 Megs of RAM is Ok. 12 megs of ram is just weird. That means you will have an 8 and a 4 Gb module. The rule of thumb for computer efficiency is to have two modules the same...be it 2, 4, 6, 8, 16, 32, etc. The reason, modern CPUs have dual memory controllers, so it pays to have 2 equal amount memory modules.
Why do they sell 12GB models then
Why do they sell 12GB models then I was looking at this onehttps://www.dell.com/en-us/shop/desktop-computers/inspiron-desktop/spd/inspiron-3671-desktop/nd3671dxsjs
I would not worry about storage you may never need. A HD is cheap and easy to install later anyways. Go for the NVME over an SSD. The NVME 2.0 looks like a stick of bubblegum. An SSD looks similar to a HD but 2.5" as opposed to 3.5" HDs. Be sure your main drive is a 2.0 NVME drive. There are slower drives that look like the NVME but are the same speed as a SSD. Are you set on Dell?
No video card in that list. There are 2 AMD CPUs with built in graphics...the Ryzen 5 2400G and the Ryzen 3 2200G. Not sure their prices.
Putting together computers is not hard Probably not much cheaper, but there's the "I made it!" aspect.List I threw together:https://pcpartpicker.com/list/zwmQ9GEqual CPU, better graphics, 16GB RAM, 500GB super-SSD, 1TB HDD, motherboard has integrated WiFi.Still need to add a keyboard and mouse and a screen, so it's not quite as cheap as it seems. Someone will find the weak spots, I'm sure.
My point? I wish I had installed a bigger SSD (perhaps at the expense of a smaller HDD).
