Multitool.org
Ranger Grip 55 mod questions 146
No Life Club Posts: 2,271
« on: May 11, 2020, 09:03:40 AM »
Hi,
Been thinking of the RG55 but I had planned removing the opener layer which I don't particularly need in an outdoors tool. I then thought of swapping the bottle opener for a small blade from a 91mm or even the main blade from an 84mm if it will fit. That would preserve the corkscrew which I use for knots and not leave an empty gap in the handle.
Any thoughts? I've never seen people modding the big stuff, what size pins would I need, would these smaller blades interact with the spring, etc?
Thanks!
« Last Edit: May 11, 2020, 09:09:39 AM by pomsbz »
Full Member Posts: 238 Custom SAK & Opinel
Re: Ranger Grip 55 mod questions
« Reply #1 on: May 13, 2020, 05:45:01 PM »
Hi,
All pins are 2.5 mm. You can use brass. The main blade's pin is stainless steel from factory. For the blades I don't know but the shape of the springs is not the same, nor the thickness.
« Last Edit: May 13, 2020, 06:00:09 PM by Michel M. »
Michel
August Goal: $300.00
Due Date: Aug 31
Total Receipts: $60.00
PayPal Fees: $3.14
Net Balance: $56.86
Below Goal: $243.14
19%
August Donations
Page created in 0.125 seconds with 33 queries.
© 2018 Defender Web & Tool
