You should mod the mini screwdriver instead!Easier to do, and cheaper to replace!!Enviado do meu Redmi Note 5 através do Tapatalk
It would be a lot of work, but you could use a round needle file and come in diagonally from the outside and work your way around the CS. This will effectively enlarge the central section. But you also need to check the pitch of the screw matches, or else it will still bind. Dremel does a small polishing pad that you can use to get the surface shiny again.Good luck, also a backer of the Fire Ant. Can’t wait to get mine...
Thanks, I would do that but I also want to add the Tortoise Gear Fire Ant and Helix Tinder. It is sized to fit in the Victorinox corkscrew and I don't think it is possible to mod.
Gearmark, could it be possible to replace the Boker's CS from a SAK's? Just a thought.
I swapped out the stupid serrated blade for a victorinox Phillips driver. Required a bunch of filing to get it to fit. I also sanded down an eyeglass driver to fit in the corkscrew. It was a lot of work too. The Boker is dog simple to mod, being screwed together. Grab a spare Vic corcksrew and see. BUT if my memory serves the square tang on the Boker corkscrew is both thicker and bigger. Thicker can be fixed with a thin washer. But the bigger tang means if you use the Vic corkscrew in its place, the backspring “snap” for the bottle opener and serrated blade will be diminished somewhat. If you can live with all of that, a 91mm corkscrew will otherwise fit. I’m not sure if the 111mm corkscrews are different than the 91mm. If they are that might be another option. Charles.
