Good job for your first I too thought it was a bit scary the first time, atleast with one of my pricier knives but it's actually quite calming and relaxing Sent fra min FRD-L09 via Tapatalk
(Image removed from quote.)And yes, it's a nice feelling.
Good first go, it takes a bit of practice but it's not very difficult to get good at.
I'd recommend using a bit of light oil or, my preference these days, soapy water. Using one of the above will have several benefits:1. keeps the stone from getting clogged with metal.2. improves the cutting action of the stone (I think....might be the same benefit as #1 above).3. lets the knife glide over the stone more easily, allowing slightly better control....which lead to better consistency.4. let you see where the edge is in contact with the stone. A small 'bow wave' is evident when the edge is on the stone and pushing the lubricant off the stone's surface. In the field, I use a little spit.
Before Reinier sees this...(Image removed from quote.)
On any kind of sharpener or just natural stones?Sent fra min FRD-L09 via Tapatalk
Learning to use a stone is great. As with anything you'll become better and better as you continue. Use a sharpie or someething to color the bevel if you plan to follow it. After a few passes on the stone feel the opposite side for a burr. Once you've established a burr time to do the other side with the same amount of passes. You should feel a burr on the other side. Pressure and angle is something on each knife you'll instinctively learn. I still mark each side with a sharpie unless I place to change to degree of angle.
Nice knives! Enviado de meu moto g(6) usando o Tapatalk
Its great you are getting them sharp . Not sure why you are scratching them . I enjoy dual stones. I have a 1000 and 3000 stone as well as a 600 and 800. I'll use a diamond course or fine when I really need to work a bevel. I always follow with a strop which IMO takes the edge nest level. I also like the traditional look of those knives
That certainly sounds like it. Usually I raise the knife as the point is leaving the stone. That will be dependent on the sweep of the cutting edge. Knife 1 and 2 don't have much of a sweep but knife 3 does. No big deal as you are learning but time to break the muscle memory. Sharp is the goal so .
Yup, I'll keep practising until I manage to get it right.
