Okay, next let's talk about the scissors, the action wasn't very smooth, and they don't spring open very wide but you can use your thumb to manually open them wider for bigger cutting tasks. I have to say though, they do their job and cut well. They went through a bubble wrap lined package like nothing.I'll give them an A-
Could you try them on paracord? Mine cut it the first time, but repeated cutting resulted in fraying cord and stuck scissors My experience with the blade was the same, the edge was not very good straight from the factory. Be careful using the awl. It has enough bite for your fingers when it collapses. How is the backspring on your awl?
I would not give it a 2, but a 3.5 sounds more realistic This tool has lots of potential, but it fell short in the execution. It needs more work and polishing to be awesome. And as you said, for the same cost there are better tools out there
I didn’t confirm anything, I only said it is more realistic
