there is one potential drawback to Alox - the backsprings are stiffer than their 91mm counterparts. Most of the time it's a good thing, to prevent accidental closure. Sometimes when you want to do something quickly, its a bit of a pain - I sometimes lose my grip on a tool and it snaps shut, so take another two seconds to open it. I don't hear anyone else complaining about it, so maybe it's just me. And normally I don't mind it... but when I go back to a 91mm after a while.... its like butter...
As for the drawbacks of alox, you can't easily swap out beat up scales like you can with nylon or cellidor. Then again, alox really takes a beating.
I dunno, I think my grandfather's OC Pioneer is a beaut in its worn down condition.-Wes.
The tools are thicker than cellidor SAKs?
Besides missing the inline phillips that is on 91mm, I also really miss the small blade of 91mm. For my use, I actually use the small blade on 91mm most majority of the time, and the larger blade is occasionally used on food.
My Farmer X came today. If you're on the fence regarding the Farmer X vs. the Pioneer, the Farmer X provides significant added capabilities in a package that is still very pocketable.
How does the weight difference feel in hand and pocket? Is the difference readily discernible or not really?
It's a noticeable difference, both in hand and in pocket. The Pioneer is listed at 2.5 oz, and the Farmer X at 3.8 oz, so half again as heavy.That said, I've carried and used quite a few different knives in my life thus far, everything from a Vic Classic weighing less than an ounce to large folders and fixed blades weighing 8 - 10+ oz. My experience is that, within a reasonable weight range and assuming that carrying isn't causing any actual discomfort, it only takes a couple of weeks to get used to a change in weight. Getting used to changes in thickness in hand and overall feel in hand (independent of weight) takes somewhat longer.In my previous post, I didn't intend to imply that there wasn't a noticeable difference; only that (IMO):The additional weight and thickness of the Farmer X over the Pioneer is a worthwhile trade-off in order to gain the scissors and saw.Even the heavier, thicker Farmer X is still easily carried in a pocket.
