You installed it? What did you harvest it from?
And my second Mini Flagship came. yay
Cheese does a better job at cutting than this tool's scissors.
And I modified a ratchet set case to store a longer extension. I really like the tanto blade.
Reamer, thanks for this review; it has been very interesting not only because of the tool, but your ability to repurpose and adapt!I'll be copying the cardboard box shopping bag holders, as I'm sure they'll tidy up my kitchen cabinet a bit. Thanks!
If that plastic is as stiff as it looks, a tanto might be just about the only one both pointy and robust enough to easily handle that job.Edit to add: A drop point might be okay. A clip point would be too likely to break off.
At home I generally use oven mitts or a hand towel or something, but whilst camping, I use the pliers for hot pots all the time. It's a good trick.
Nice use, RP, and your dinner looks very tasty; enjoy!
I like the drill bit in the bit extender. That's probably a bit outside the original spec.
Nice job on the handle! Would you say the saw was comparable to Leatherman's, Gerber's ,SOG's, or none? Jist curious.
