Multitool.org
SAK 93mm CAD file 181
New User Posts: 2
SAK 93mm CAD file
« on: May 30, 2020, 11:35:55 AM »
Hi,
I am looking for a file to use in CAD (STEP, DXF, ...).  I have already attempted to draw it myself, but I am not a professional.
Thanks for the help  :cheers:
No Life Club Posts: 1,537
Re: SAK 93mm CAD file
« Reply #1 on: May 30, 2020, 01:02:44 PM »
I haven't come across a 93mm one. The best 91mm I've seen is at https://grabcad.com/library/sak-kit-victorinox-swiss-army-knife-huntsman-ruler-torch-1992-1. It is likely modelled on visual cues and measurements alone so probably off here and there - but looks good.
If you just need a model for some visual renderings then TurboSquid might have something that looks more or less right.
I guess the manufacturer is the only one to have the actual CAD files? (Well, and maybe all the copycats having done proper measurements in order to cut corners and make cheap copies).
"If only simple wasn't so hard" - me
August Goal: $300.00
Due Date: Aug 31
Total Receipts: $60.00
PayPal Fees: $3.14
Net Balance: $56.86
Below Goal: $243.14
19%
August Donations
Page created in 0.037 seconds with 33 queries.
© 2018 Defender Web & Tool
