I'm interested in a comparison to the LM file whose diamond side works great (the other side and edge don't work very well) as well as the wire cutter feature. The LM wire cutters are rather weak, how do these compare?Any other thoughts?
Wow - What sacrilege is this I am sure you all know I am a big Vic fan - Although I do love my LMs too.- But I gotta agree - I only ever carry a small SAK as EDC.Although I usually add the Juice into my pocket at the w/e for small jobs around the house - This has made me think I might just try the SwissChamp for the weekend.Interesting point about the WorkChamp Alexanderre - Good call - Especially for those camping trips - That model really is a powerhouse - With a broad set of tools/capability.And outside opening tools are just the best. So much more convenient - I do find my LMs a tiny bit frustrating/inconvenient for that !This has also made me think I need to try my diamond file a bit more - I hardly ever use it!!What do you guys use it for? - Just sharpening blades?Good discussion
The Vic metal file/metal saw is good for what it is, though not the equal of the LM diamond file.The wire cutters on the 91mm pliers are well-made and, in my experience, will cut through just about anything that will fit in their jaws. However, due to the short wire cutter edge length and the jaws only opening so far, this criterion is rather limiting.Overall, I think you're making the right move! I've often wondered why anyone who doesn't get a lot of use out of the pliers or wire cutters would choose a pliers-based MT over a knife-based MT, for all of the reasons you've stated.
I missed this thread when I made the observation that the Ranger was a plierless Swisstool X, and if you carry the knife pliers why bother with the extra thickness of the Handyman?
How dare you be so logical! Truth is that my knipex are very blunt nosed and of course I have no wire cutting abilities at all, hence thinking of the Handyman. Question is whether the SAK pliers can fill that hole at all. It's an issue that I've never actually held them in hand and I have a feeling that I will not know till I actually see them.
The wire cutting ability of the SAK pliers is almost nonexistent. If you want' need to cut anything bigger than a paper clip size wire, you're out of luck.Not the best pictures, but you can see that the wire cutting "notch" isn't very big.
I wonder if I should think of the Ranger instead.
I just ordered one After (yet again) extensive thinking about the pros and cons of several SAK models, I decided to give the Huntsman another look. Only issue was the missing ability to manipulate metal. I like the Handyman, but i don’t need pliers very often, and I wanted a smaller SAK. That’s were the Ranger comes in. Wanted the newer version though, because the metal saw is more aggressive. I’ll let you know how i like it once it arrives
Yeah - I had reasonable success on small wire too - But don't ever try on stranded wire!!
