Wave & Rebar mod
Re: Wave & Rebar mod
Reply #30 on: January 08, 2024, 09:12:11 PM
Today modded again my Rebar, removed scissors and Bitdriver, replaced them with Wingman flathead and phillips (phillips only cause didnt know what to fill gap, but it jas been useful so far) main reason to changebwimgman flathead was that i wanted prying tool. Wingman flathead can actually handle much more prying than orginal.
Only Tools Matters
us Offline IMR4198
Reply #31 on: January 09, 2024, 01:02:02 AM
    Good looking mod there, Antti.  The Wingman flat point is a really stout tool.  The edges are fairly sharp, so it makes a pretty good scraper as well.  I hope your construction situation is coming along for you.  Best wishes.  Gary
Reply #32 on: March 07, 2024, 03:27:40 PM
Since i modded Rebar saw to my Center Drive (parts are now heading to Barry) my modded Rebar was missing saw.
Because that i decided to mod my own saw to it, used Wurth Heavy Duty Foxtail saw blade for base of my mod.
From one blade you can make 2 saw, drawed lines to it and started grinding material away and the drilled hole to it to. Decided after first saw that i need bit better tools than dremel and drill. It was awful job to grind with dremel, next time i will need to lend grinder to get bit better result.
Saw is rough looking but it can now saw metal and wood. It wiggles bit since i made accidentally too large lock notch (next time need to be careful not to enlarge it too much)
Now my modded Rebar has
- Heavy Duty Saw
- Wingman Large Flathead
- Awl
- Wingman Phillips
- PE Blade
- SE Blade
- Metal Saw
- Rebar Phillips
- Rebar Small Flathead
- Wood/Metal File
- Rebar Pliers with Replaceable Cutters
I would say that now it can handle most jobs i can imagine (for scissors i carry Pioneer X) and since i have removeable Bit Driver i csn use flatbits and regular 1/4" bits.
Only Tools Matters
Reply #33 on: March 07, 2024, 08:48:50 PM
Awesome idea to make a saw from that recip blade, Antti :o :salute: :like: :like:
Reply #34 on: March 08, 2024, 02:07:48 PM
Thank you Poncho. I discovered that i could try to make saw for Rebar, basicly just needed model and bit of patience to do it. I will try improve next version bit better fit and cleaner look for it. I tested saw for wood and it cutted it like charm, at work we use those blades to cut wood, nails, metal frames and etc...
Only Tools Matters
Reply #35 on: November 12, 2024, 03:46:07 PM
Well now that Poncho modded PST i was bited modbug and made hybrid model.
Wave handle with modded serrated blade (chisel head) , Vic scissors, medium flathead, awl and microbit driver.
Rebar handle, file from Rebar, Wingman flathead, phillips and custom heavy duty saw and Rebar pliers. I will call this abomination as WingReVe.
I may need to make few adjustment for tools but since im on PST challenge i wont be using this so much before challenge ends, maybe few testing.
Reply #36 on: November 13, 2024, 11:41:05 AM
It's got an awesome toolset for sure  8) I had one similar to this for a while but ultimately I took it back apart and made a Wave and Rebar again :salute: It worked very well but I just didn't carry it enough :cheers:
Reply #37 on: November 13, 2024, 02:25:53 PM
So far what i have handeled it, it feels bit weird on hand and pocket but toolset is good.
I could build Rebar for parts i have but not Wave anymore since i have sold parts of it.
I may need to haul more tools to dissamble and sell extra parts what i dont need.
Reply #38 on: January 08, 2025, 02:36:06 AM
I'm catching up, but I love your mods Antti!
