Hmmm.....the rivets on my Farmer X are raised, but no more than a Pioneer or Farmer.
I know it's very hard to unnotice once noticed, but I would just live with it... I don't think it would damage your trooos?
It is not up to Victorinox standards. This is a real slip in Quality Control. My uneducated guess is that the countersinking in the alox scales might have been to shallow for the rivet head.
This is what my old soldier looks like...
I bet they altered how they do the rotary head riveting for the wider build. If you put too much force down the pin bends internally. So they dialed back the force and the result is the heads aren't always flush. They had a similar problem with pioneer x as some of the first few had bent internal pins.
Interesting idea. I believe Vic uses the same scales on all 93mm knives, the only physical differences being in the colour of the anodising and the shop logo on the back.So if the Farmer X is having this problem, then so are the pioneers, electricians, etc.Anyone have a brand-new stock pioneer to check?Another possibility is that the either the rivets are too long, or the machine isn't peening the rivets far enough. Both of these specifications are unique to the Farmer X, which would explain why it's the only one so far with the raised heads.
Here are my best efforts with my Pioneer (LE 2020) Hope this helps?
I just looked at a Farmer and Cadet in my nightstand drawer. I bought these close to 10 years ago and they both exhibit a slightly higher middle rivet on the scale with the little engraving plate. If I try, I can feel the edge. My guess is that's how it's been with these Alox scales for awhile. While I like the *looks* of Alox scales, I prefer the Celidor scales because I miss the toothpick and tweezers on Alox scaled SAKs.
So the verdict is that I'll have to live with it or send it in for warranty? Does Vic even accept these colored models?
