Cutting packaging tape
00 Offline Sam Lim
on: August 03, 2020, 02:29:25 PM
Another can shed some light on this.... Recently I am required to open alot of packaging at work. The packing tape that they use are those that seems like paper tape/masking tape but reinforced with threads, I am guess nylon? The problem I have is no matter what knife I use, be it a LM 420hc or a regular spydie 8cr13mov, they always dull up super quick. Maybe around 20 cuts and they dun slice paper anymore. I usually begin with hair shaving sharp, 20degree/side on a lansky.
Anyone can advise if they are really that abrasive?
Re: Cutting packaging tape
Reply #1 on: August 03, 2020, 03:31:54 PM
How about using a X-acto knife? Their blades are razor sharp and cheap as dirt. Maybe that's the best option.
 :think: :think:
00 Offline Sam Lim
Reply #3 on: August 03, 2020, 08:03:50 PM
 :salute: I can understand a box cutter are called box cutters for a reason. But that brings away the fun part of carrying a "knife"... I am just re-thinking, sharpening error or something else.. Or its just a bad idea to use them for this purpose.
Reply #4 on: August 04, 2020, 01:57:35 AM
Cardboard and packing tape can really dull a blade fast :ahhh I think it has to do with some of the materials in cardboard  :think: I am sure there are materials in that type of packaging tape as well :salute:
Replaceable type blades are the go to for this for me when there is a lot of opening of packages but I do use my regular carry still if not much to cut :cheers:
us Offline smiller43147
Reply #5 on: August 04, 2020, 06:16:29 AM
 :iagree:  Cardboard will dull any knife quickly.  The paper packing tape likewise, and the plastic tape will gum up the blade with adhesive.
Get a utility knife and a contractor's pack of disposable blades.
- Steve
Reply #6 on: August 04, 2020, 06:36:48 AM
That paper tape plus whatever the filament is I'm sure is part of the issue.  As said cardboard is pretty aggressive on edges as well.  Your edge doesn't seem to acute?  I'd even suggest going to 15-18 degree per side and see how that performs.
00 Offline Sam Lim
Reply #7 on: August 04, 2020, 06:45:03 AM
I dun usually cut the cardboard. Just the tape and they are doing enough damage. I had tried steeper angles before freehand but that seems to be worse for me.. Now more recently using more of the lansky, 17 degree usually doesn't work well as I use smaller blades and the stones will hit the clamp. Guess its time to look for a proper utility blade rather than something "fancy"...
Reply #8 on: August 04, 2020, 06:50:21 AM
You just need a cool box cutter, to bring back the fun.
00 Offline Sam Lim
Reply #9 on: August 04, 2020, 03:37:42 PM
I am looking for a Gerber Prybrid. Should be cool enough. 😂
Reply #10 on: August 04, 2020, 03:57:22 PM
Sos thats very cool  :like:
00 Offline Sam Lim
Reply #11 on: August 05, 2020, 04:17:34 AM
But when I looked at the reviews, the sliding tabs seems a bit stucky... And I didn't know that thing is so large.. Didn't like the X version as its more of a crafts knife.. Hmm...
Reply #12 on: August 05, 2020, 06:02:26 AM
I thought that Stanley I posted a link for was kind of cool.
Reply #14 on: August 05, 2020, 06:09:43 AM
Reply #15 on: August 05, 2020, 08:00:20 AM
Thanks
Shame to hear the reviews for the Gerber Prybird aren’t looking like it will meet your needs.
This one is kind of cool as well
https://www.amazon.com/MOSSY-OAK-2-Piece-Standard-Retractable/dp/B0751B7WXR/ref=psdc_553240_t3
_B00IA14854
:agree:  There are several cool utility/razor knifes, just like other knives.  Just have to find the one that meets your needs and desires.
Here are some others
https://everydaycarry.com/best-utility-knife
00 Offline Sam Lim
Reply #16 on: August 05, 2020, 12:30:01 PM
Thanks for all the links and suggestions 😘. I have the mossy oak cutter just that mine is the workpro brand. And I stole that pocket clip for something else... Its a little slim and slippery for 1 handed opening.. Had the EAB also.. Struggle to open 1 handed as well.... I am picky and irritating eh....  :P
August Goal: $300.00
Due Date: Aug 31
Total Receipts: $25.00
PayPal Fees: $1.53
Net Balance: $23.47
Below Goal: $276.53
 8%
August Donations
