If it's an "extra" hold on to it if you ever want to buy scissors for that tool.. If I remember correctly, you need an extra washer for the scissors..
Ok will due. I'll slide it inside a zip lock and file it in a safe place. With all due respect unless they re-design those current scissors I'd rather just put a spacer in the tool instead.
Lots seems to have been posted regarding those units and I have to admit I made 2 pinches on them in the store and said "do you have the tool with the v-cut?"
Ok thanks for the info fellas. Come to think of it I noticed I had to tighten the one side containing the file up a bit with the 1/4 in bit. Where are there suppose to be washers in this tool probably the edges for sure right? Anywhere else?
thanks
