NYKC Hammer Brand 2-blade Jack knife
00 Offline kwakster
on: August 27, 2020, 06:11:05 PM
Recently i bought this old Hammer Brand 2 bladed jackknife, made by the New York Knife Company in Walden, New York.
The company was operational from 1856 until 1931, when it closed it's doors.
The main blade seems to have an early version of the arm holding a forging hammer, and this is how the knife looked when i got it.
The blades on these knives were forged from crucible steel:
Old image of the New York Knife Company situated on the Walkill River.
00 Offline kwakster
Re: NYKC Hammer Brand 2-blade Jack knife
Reply #1 on: August 27, 2020, 06:11:34 PM
On most period Hammer Brand knives the tang stamp shows a shorter upper arm section with a bulging bicep, while on mine the upper arm is more elongated and without that pronound bicep.
Speculating i would think that the bulging bicep could be seen as an improvement from a marketing point of view, making the tang stamp on my knife an older version.
Picture from the tang stamp with the more commonly seen muscular arm:
The stamp on my knife:
00 Offline kwakster
Reply #2 on: August 27, 2020, 06:12:02 PM
As i intend to carry & use this well made old knife for a while i'm treating it to some TLC.
Already cleaned everything thoroughly using toothpicks, a old toothbrush, an ultrasonic cleaner, and also electrolytically.
Then removed the bladeplay in the pivot and gave the old wood panels a few coats of IKEA mineral oil and a topcoat of Granger's wax.
Currently in the process of reshaping & regrinding both blades, the points of which now don't stick out of the handle in the closed position anymore.
This is the smaller blade after hand regrinding it ever so slightly convex on 400 grit wet & dry SiC paper clamped on a piece of hardened glass using WD40 as a lubricant.
There's a visible burr all along the edge, so it's now ready for one or more refining steps.
The single sided swedge was redone with a small diamond file.
And the larger blade.
It's double sided swedge was also redone with the small diamond file.
00 Offline kwakster
Reply #3 on: August 27, 2020, 06:12:38 PM
How the main blade currently looks.
It's surfaces have for now been finished on 1000 grit wet & dry on a semi-hard rubber backing using WD40 oil as a lubricant.
A microbevel has been applied on the white sticks of a Spyderco Sharpmaker at the ~30 degrees inclusive setting, again using some WD40.
And the smaller blade:
00 Offline kwakster
Reply #4 on: August 27, 2020, 06:13:04 PM
The finished knife.
Both blades can now shave armhair above the skin, the joints have had a few drops of 5-weight Nano-Oil, and the knife is fully usable again.
Reply #5 on: August 27, 2020, 06:28:21 PM
Noce knife and very nice job cleaning and restoring it.
Offline Ray S
Reply #6 on: August 27, 2020, 06:32:52 PM
Beautiful job on a great old knife!  There is a list of tang stamps on the AAPK website;I'll check and see if I can date the knife.That can be a difficult proposition as most companies didn't keep good(or any)records in regards to changes in stamps or the like.
Reply #7 on: August 27, 2020, 06:40:49 PM
Nice job  and cool old knife
Reply #8 on: August 30, 2020, 02:00:40 AM
Verah nice Jack knife from one of the top knife companies of their day. If I remember correctly Hammer Brand was the top of the line of the NYKC.
Reply #9 on: August 30, 2020, 04:28:12 PM
I only recently became familiar with this maker.  Very nice oldie you've got there.   :like:
00 Offline kwakster
Reply #10 on: September 02, 2020, 06:14:10 PM
Found this interesting background information about the American pocketknife industry, by Walden village historian Mary Ellen Matise:
Reply #11 on: September 03, 2020, 03:27:16 PM
 :tu: Thank you.  I'll watch later for sure.
Reply #12 on: September 04, 2020, 11:10:49 PM
Here's a book that is a wealth of information.
