SAK Alox drilled & tapped pivots 778
Newbie Posts: 43
« on: September 02, 2020, 02:00:13 PM »
Hello all.  Long time reader here but I've never posted.
I want to change a Pioneer SAK to Torx.  I have most things I need including M2 T6 screws, but I can't find appropriate pivots anywhere.  Can anyone supply 3mm and 2.5mm pivots to fit my M2 screws?
I'm not certain of the exact length... Maybe someone knows that?  Though of course I could measure and cut them to the correct size.
Thanks in advance!
No Life Club Posts: 4,719
Re: SAK Alox drilled & tapped pivots
« Reply #1 on: September 02, 2020, 02:25:11 PM »
No Life Club Posts: 3,910
« Reply #2 on: September 02, 2020, 02:29:12 PM »
Hi sgjs,
Welcome!
This depends where you live and others from your place may want to chime in to complete my 2 cents, to wit:
Not sure where I should get them (I haven't tested any of those offered ready-made) so I make them myself from solid brass stock in the appropriate diameter. Then I drill at 1.5 mm (this should be 1.6 nominally but 1.5 works just fine in brass) using a lathe and tap M2 thread.
Hope this helps...
Cheers!
Dutch_Tooler
Newbie Posts: 43
« Reply #3 on: September 02, 2020, 02:34:29 PM »
Hi sgjs,
Welcome!
Hope this helps...
Thanks for that info.  I live in the UK.  Your method sounds Ideal, though I don't have the tools and I'm not that technical...  I think I will try those that RF52 suggested.  They look ideal.
Unless perhaps you'd be willing to sell me some that you have made?  Obviously I understand if not    :)
Newbie Posts: 43
« Reply #4 on: September 02, 2020, 02:34:48 PM »
No Life Club Posts: 4,264
« Reply #5 on: September 02, 2020, 03:43:06 PM »
I bought some of those from that guy. They work great.  Looks like his shop is currently closed though.
The hardest part was drilling out the rivets. Even with my little bench top drill press, I screwed up my scales.  Luckily it was on my beater PX, and it’s still functional.
Newbie Posts: 43
« Reply #6 on: September 02, 2020, 04:04:09 PM »
Hey that looks great!
Yes I saw he was away.  I found his ebay shop and ordered a set there.  Hopefully when he returns he will ship my order.  I might try the drilling today to get the hard part over with.  I only have a hand-held drill so even harder than it was for you I guess!
S
« Reply #7 on: September 02, 2020, 04:52:39 PM »
I don't keep any pre-made, I just make them when needed, sorry...
Cheers!
Dutch_Tooler
Newbie Posts: 43
« Reply #8 on: September 02, 2020, 05:08:41 PM »
No Problem   :)
Newbie Posts: 43
« Reply #9 on: September 02, 2020, 05:12:22 PM »
Phew!  that wasn't easy, but I managed:
Newbie Posts: 5
« Reply #10 on: September 05, 2020, 08:38:42 PM »
This guy has some, never bought any so can't say how they are.
https://www.etsy.com/listing/727619812/3-mm-118-mm-pivot-barrels-no-screws
https://www.etsy.com/listing/741477235/25-mm-118-mm-pivot-barrels-no-screws
I've bought these before, they are good quality and works well for the mod I did.
Shipping does take a while, and probably will during these times.
Newbie Posts: 6 What can I cut next???
« Reply #11 on: September 20, 2020, 04:07:28 PM »
Greetings all,
As a newbie here, I thought I would begin with my first posting here.
I have been on the hunt for 91mm and 93mm scales to start my own modding and in searching, have found threaded 2.3 & 2.5mm pivots on several shops on Aliexpress.  Yes, I know that they are available through Alpha Supply if I want the 1/8mm ones and drill out my tools, liners and so forth.  The "sets" (as they are being sold) are about $10 with shipping and will include (2) 2.5mm and (1) 2.3 mm pivot.  They are sold for 2 layer or 3 layer builds and you will need to specify which length you want when you add them to your shopping cart.  I have not personally ordered any as mine came from DeCustomForge on Etsy.  Just throwing it out there as an alternative to the sources already mentioned here in these forums.
If I ever bore you, it'll be with a knife.
Louise Brooks-
New User Posts: 3
« Reply #12 on: September 21, 2020, 11:48:06 PM »
thanks for the tip. From another newbie!
Zombie Apprentice Posts: 19,357 Oxygen and magnesium toghether?! OMg!
« Reply #13 on: September 22, 2020, 04:10:08 PM »
Welcome and thanks for sharing!
 :cheers: :tu:
Full Member Posts: 146
« Reply #14 on: September 27, 2020, 02:44:34 PM »
tlcrawford, can you provide the links for the pivots? I can't locate them on Aliexpress.
February Goal: $300.00
Due Date: Feb 28
Total Receipts: $132.48
PayPal Fees: $7.93
Net Balance: $124.55
Below Goal: $175.45
42%
February Donations
Page created in 0.054 seconds with 33 queries.
© 2018 Defender Web & Tool
