Login
Register
Menu
Home
Help
Forum
Non Tool Forum
The Break Room
Plumbing help much needed
chip
8 ·
573
« previous
next »
Print
Pages:
1
Go Down
chip
No Life Club
1,382
on:
September 11, 2020, 08:33:28 PM
Hi, I had a new boiler fitted at the start of the year and soon after (days) found the drain cock they drained down from was leaking. They sent someone out who apparently repaired it.
The drain cock in question is located in a void in the wall behind my freezer. Anyway last week I discovered the drain cock was still leaking and got a family friend in to replace it. He drained down the central heating system, replaced the part and then refilled the system. Fast forward a few days later when my central heating is on two of my radiators have a noisy dripping, trickling sound coming from them. The radiators are red hot and I tried bleeding them and no air came out of them.
Today the friend of the family came back on a motorbike so no tools and also tried bleeding them and again no air came out just water.
I don’t think he knows what hat the problem is but is coming back tomorrow with his aqua vacuum and is going to open the bleed valve and put his vacuum over the bleed point to see if it will help.
Any plumbers please watch the vid and all ideas welcome. Thanks in advance.
https://youtu.be/UBhZ98Ws_38
Merit Badges
MadPlumbarian
Point Of No Return
37,077
Plumbers Know Their Crap!!
Re: Plumbing help much needed
Reply #1 on:
September 11, 2020, 08:50:35 PM
What’s the system? It kinda sounds like it’s trying to gas ignite, at the same time it sounds like the metal is expanding from the heat, any other pics?
As I sit on my
Crapper
Throne
in the
Reading Room
and explode on the
Commode
, thinking, how my flush beat
John’s
and
Jerry’s
pair?
Jack’s
had to run for the
Water Closet
yet ended up tripping on a
Can
bowing and hitting his
Head
on the
Porcelain God
Merit Badges
chip
No Life Club
1,382
Reply #2 on:
September 11, 2020, 09:03:51 PM
It’s just a normal boiler with tanks in the loft. The boiler seems to be running ok. All the radiators are heating up ok it’s just the dripping sound coming from the two radiators. One Upstairs in the bedroom and the other in the hallway downstairs below the bedroom. What pictures would help?
Merit Badges
chip
No Life Club
1,382
Reply #3 on:
September 11, 2020, 09:06:20 PM
The really fast ticking sound above the sloshing water sound is my electricity fuse board that is mounted directly above the radiator.
Merit Badges
MadPlumbarian
Point Of No Return
37,077
Reply #4 on:
September 11, 2020, 11:43:25 PM
Sorry, we had a appointment,
If that really fast tick hasn’t got anything to do with it then it sounds like air is moving through your lines, somehow is not bleeding, there should be a scoop valve around the boiler so every time air passes through it catches it and then another little valve on top that spits it out,,
As I sit on my
Crapper
Throne
in the
Reading Room
and explode on the
Commode
John’s
and
Jerry’s
pair?
Jack’s
had to run for the
Water Closet
Can
Head
on the
Porcelain God
Merit Badges
chip
No Life Club
1,382
Reply #5 on:
September 12, 2020, 06:27:17 PM
Ok, thanks for your help, sounds like it is not an issue I should be overly concerned about. I
Merit Badges
MadPlumbarian
Point Of No Return
37,077
Reply #6 on:
September 12, 2020, 08:51:27 PM
Quote from: chip on September 12, 2020, 06:27:17 PM
No, air moving through the system isn’t something to be concerned of, just really annoying hearing it hit the elbows, if your systems are the same there should be a setup similar to this, that can has a rubber dome like a balloon which you can add pressure on the bottom, but that absorbs the shock of the system, at the same time that scoop valve (the one attached to the pipes) allows the air in and scoops the air up since it raises, it then goes to that next valve that only allows air out of the system to be released out the top, check on the top of that valve cause there might be a cap on it like on a bike tire, and it might not be allowing the air out,, just a thought..
(Filesize: 125.91 KB)
As I sit on my
Crapper
Throne
in the
Reading Room
and explode on the
Commode
John’s
and
Jerry’s
pair?
Jack’s
had to run for the
Water Closet
Can
Head
on the
Porcelain God
Merit Badges
Mechanickal
Zombie Apprentice
14,686
Reply #7 on:
September 12, 2020, 09:12:48 PM
Yup, my valves turned out to be closed a few weeks ago after we changed the threeway valve.
Opened them up and after a short time, all remaining bubbles were gone.
Merit Badges
Print
Pages:
1
Go Up
Forum
Non Tool Forum
The Break Room
March Goal:
$300.00
Due Date:
Mar 31
Total Receipts:
$379.86
PayPal Fees:
$19.62
Net Balance:
$360.24
Above Goal:
$60.24
Site Currency:
USD
120%
March Donations
Powered by
EzPortal
Search
This topic
This board
Entire forum
Google
Username
Password
Always stay logged in
Forgot your password?
