I don’t worry about it much on modern knives. I generally won’t do that with vintage or valuable/collectibles. Knives from say the ‘40s maybe ‘50s and earlier can crack their backsprings. Maybe the liners if they’re already damaged. Even in modern knives it is also bad for the pins. They take enough shear and bending in normal use.
These are pins removed from a vintage knife. The longer top pin was straightened for reuse.
Yes, I think in my Sportsman's case it's much more likely that the centre pin's bent. The 84mm range has thinner pins than the larger ranges and if my Recruits are are indicative, the back tool pin seems to be a weak point. My Recruits' flat SDs have excellent snap.
Were the old pins made of brass, as now? The ones in your pic look like an alloy. That damaged one - crikey.
Yes, they’re Nickel Silver. Used for most exposed pins in much of Victorinox history. Yeah I’m surprised that one came out without major effort!
The liners were NS as well, right? How do the pin holes hold up? Did they change to brass pins for their increased strength? A shame about the change to Al liners, though. Hate when they get corroded.
How do the pin holes hold up? A shame about the change to Al liners, though. Hate when they get corroded.
