Squirt PS4 replacement spring
Riez · 7 · 4211
nl Offline Riez
  • New User
  • Hi, I'm Riez from the Netherlands
on: November 01, 2020, 01:05:25 PM
Hello all,
As an intro, I'm new to the forum and truly amazed by the enormous amount of knowledge here. Thank you for sharing!
I own some Leathermans and Victorinoxes in various forms and shapes.
Among those a Squirt PS4 with Torx screws, slightly modded to fullfill my daily requirements.
Now, as with many of us, the spring on the scissors has broken. I'm not sending it back to Leatherman as they will replace it with one without Torx and I will loose my modds.
Now, I learned on this forum that some of you, or at least Tattoosteve, have been able to make a new spring themselves and even provided that to others.
Is there anybody please that can point me to a source for such replacement spring? I would highly appreciate that.
Thank you in advance!!
Kind regards,
Riez
Regards,
Riez
Re: Squirt PS4 replacement spring
Reply #1 on: November 01, 2020, 01:18:04 PM
Can't help you with the spring but welcome to the forum.   :cheers:     Hopefully someone will be along soon that can help you    :tu:
Offline ComboTool
Reply #2 on: November 01, 2020, 02:22:29 PM
Maybe someone already has the part you need, you can ask in the "tools needed" forum. Otherwise my suggestion would be to get a used/broken Squirt and scavenge it for the spring.
00 Offline Sam Lim
Reply #3 on: November 03, 2020, 05:48:43 AM
I did this a little while back for the squirt scissors.
nl Offline Riez
  • New User
Re: Squirt PS4 replacement scissors spring
Reply #4 on: November 04, 2020, 10:13:41 AM
Well done! Looks like a good solution to the problem. Also more permanent as the Leatherman structure. Did you make the spring yourself or did you take it from another tool?
Regards,
Riez
00 Offline Sam Lim
Reply #5 on: November 06, 2020, 04:13:47 AM
That metal piece was from a binder clip. They are springy enough and retains it's shape well.
poiuy1412
  • Guest
Reply #6 on: October 17, 2024, 10:50:58 AM
How did you managed to attach a binder clip for the scissor thing? Can you upload more pictures about the scissor spring since I have the same problem?
