One handed Spirit, the MXBS 4732
Admin Team Point Of No Return Posts: 33,348
Re: One handed Spirit, the MXBS
« Reply #30 on: November 10, 2020, 12:16:56 AM »
This is definitely one that I know a lot of people have been waiting for!  I don't think the tabs look like they're going to be massively in the way.
Try not to be the person who blunders around and causes everyone else to get out the way.  Everyone else thinks you're a utter...
OCD Squad Leader Admin Team Zombie Apprentice Posts: 11,861
« Reply #31 on: November 11, 2020, 06:08:23 PM »
First impression
Just unpacked them. Getting it out of the sheath was very difficult.
The tabs are not sharp, but they stand very proud, so there is a good chance they generate some nasty pressure points in the pockets. Also, not a fan of the blade-grind. That said, they work very well.
Will carry it for a while, but I'm almost certain that the benefit (OHO) does not outweigh the drawbacks (blade-grind, hot-spots).
Emergency Kit: Ovo Sport, chocolate, cheese, crispbread and a coin
No Life Club Posts: 2,851
« Reply #32 on: November 11, 2020, 06:29:45 PM »
First impression
:popcorn: :popcorn: :popcorn:
They don't like it up 'em!
Hero Member Posts: 801 MAJ/APA
« Reply #33 on: November 11, 2020, 06:41:06 PM »
 :like: :tu:
Zombie Apprentice Posts: 14,648
« Reply #34 on: November 11, 2020, 07:59:16 PM »
First impression
How?! :sa:
Did you ask if it'll be available everywhere? :dd:
« Reply #35 on: November 11, 2020, 08:42:31 PM »
How?! :sa:
Magic...
ordered it from Singapore (shipping rate was reasonable and it was here lightning fast)... a well traveled knife :facepalm:
« Reply #36 on: November 11, 2020, 08:54:10 PM »
Magic...
That was fast indeed...
Here's me hoping ...
« Reply #37 on: November 11, 2020, 10:19:30 PM »
Not fitting the sheath well.
The last one shows the deformation of the sheath without the tool inside!
Absolutely No Life Club Posts: 5,676
« Reply #38 on: November 11, 2020, 10:28:47 PM »
you'd think they would have done a cut out or redesign to accommodate the different shape?  :dunno:
No Life Club Posts: 4,892
« Reply #39 on: November 11, 2020, 11:01:51 PM »
The OD Green "rubberized Cordura" sheath would've been perfect, but they go with the stiff regular sheath. It makes no sense to me. That's an off-the-shelf-solution to the tightness, as the OD green sheath has more "give", is capable of horizontal/vertical belt carry, MOLLE, and whatever else you need to strap it to.
Absolutely No Life Club Posts: 5,549
« Reply #40 on: November 12, 2020, 02:23:08 AM »
I prefer the sheath they picked, it feels way more sturdy as the green MOLLE sheath, and judging from the pics I think it will change shape a bit after a while and handle the OHO thingy's without any problem.
The Lock on my Victorinox S54 also pokes in the side of the sheath I got for it (same material as the one above), and after a while it fits much better.
I mean, it could be worse... My Leatherman OHT with the small Leatherman MOLLE sheath comes to mind...
Newbie Posts: 21
« Reply #41 on: November 12, 2020, 02:24:46 AM »
I think they use that sheath for the black oxide version.
https://www.military.sg/shop/home/2133-victorinox-swiss-tool-spirit-mxbs-australian-army.htm
I hope to be able to confirm in a few days, it is on its way.
Newbie Posts: 21
« Reply #42 on: November 13, 2020, 12:02:03 AM »
Yes, the BO version uses the OD green sheath.
« Reply #43 on: November 13, 2020, 01:47:41 AM »
Have to say I like it a lot, my solution for the wings
Absolutely No Life Club Posts: 6,836
« Reply #44 on: November 13, 2020, 04:06:35 AM »
Agree.  Mine arrived today.
(The black is consistent, the difference in the pic is just shadows
Being left-handed, I was curious to see how the tabs worked for LH OHO.  The serrated belt cutter opens with the thumb easily in the LH.  To open the PE blade LH, I need to use my finger reaching around the Spirit to start opening and then adjust grip to finish opening, similar to LH opening of both blades on Wave.
Mine probably won’t spend much time in the case, because it will more often be in my organizer which it fits nicely.
« Reply #45 on: November 13, 2020, 04:54:44 AM »
Something else I find strange besides the blade grind, which I can fix is the fact they shortened the main blade by a few millimeters (2.5”/6.2 cm) compared to the S, RT, or XBS (2.7”/6.8 cm).
« Reply #46 on: November 13, 2020, 05:29:59 AM »
It must be a new blade blank that they stamp for the stud, so probably this has resulted in a small difference on the blade length.
No Life Club Posts: 3,278
« Reply #47 on: November 13, 2020, 06:43:01 AM »
The tabs presumably make it easier to find the main blade... on the normal Spirit I usually pull at the metal file and the saw before eventually finding the blade I'm looking for... all that symmetry is too much for a simpleton like me.
Zombie Apprentice Posts: 14,378
« Reply #48 on: November 13, 2020, 08:59:40 AM »
Probably because when using the thumb stud you're now pressing the blade to the middle of the tool a bit when opening. That could cause the blade tip to get caught onto the "pliers spring".
Formerly known as MTMatt
Sr. Member Posts: 493 Unless
« Reply #49 on: November 13, 2020, 06:41:33 PM »
This would be ideal for the Dutch army, combing the functions of their DAK (OHO blade and belt cutter) with the issue Spirit’s tools.
Could also be useful for the Swiss Army but with the saw blade reinstated.
"Unless someone like you cares a whole awful lot, nothing is going to get better. It's not."
― Dr. Seuss, The Lorax
Full Member Posts: 149
« Reply #50 on: November 14, 2020, 06:53:24 PM »
I can the need for the rescue cutter on a military tool, but I'm baffled by the lack of a saw.  One would think that a saw would be of much more use to the average soldier than a file.  If these become available in the US, I would certainly pick one up and just carry an 84mm walker with it then I'd have all my bases covered with a pretty light weight, compact package.
« Reply #51 on: November 20, 2020, 09:03:52 PM »
Finally have a video on YouTube https://youtu.be/yzXQ-qFtXVg
Thread Killer 2017 Absolutely No Life Club Posts: 8,545 Born to multitask.
« Reply #52 on: November 21, 2020, 08:22:03 AM »
I'll use this as the MXBS Owener's Club, unless someone wants to make one.
Sr. Member Posts: 359
« Reply #53 on: November 21, 2020, 12:07:22 PM »
Nice video!  :tu:
Gosh, I really want one of these in BO. Ideally with a saw instead of the scissors, that would be near perfection.
« Reply #54 on: November 21, 2020, 12:38:47 PM »
Nice video!  :tu:
Ben (Texas Tool Crib) is a member here, but he does not post that much. :(
But at least he makes great videos! :like:
Absolutely No Life Club Posts: 9,027
« Reply #55 on: November 21, 2020, 01:14:31 PM »
Nice video!  :tu:
 :iagree: I can't believe they left out the smurfing saw!  I swear they do this just to wind me up!  :ahhh
« Reply #56 on: November 21, 2020, 01:42:51 PM »
The Victorinox design team: "We are going to design the perfect Spirit, people have been asking for one handed opening for a long time. Ooh, I know, let's not put in a saw, we'll use these tiny scissors that don't open very far. That will keep the fans nicely riled up".  :ahhh  :twak:
I really don't dislike the Spirit scissors that much, it's just that I would prefer a saw in this particular tool.
« Reply #57 on: November 21, 2020, 03:19:08 PM »
...I sure hope it's not my fault  :ahhh
Should not have posted the pics here last year....
« Reply #58 on: November 21, 2020, 03:21:27 PM »
I didn't even take 2 days with my new Spirit XBS until I had to widen up the scissors opening...  ::)
I just couldn't tolerate it.
« Reply #59 on: November 21, 2020, 03:42:48 PM »
Completely forgot doing that on mine. Guess I really don’t dislike my fixed scissors.  :)
Ouch!
August Goal: $300.00
Due Date: Aug 31
Total Receipts: $10.66
PayPal Fees: $0.63
Net Balance: $10.03
Below Goal: $289.97
 3%
August Donations
Page created in 0.055 seconds with 33 queries.
© 2018 Defender Web & Tool
