Recommendations to pair up with a Rebar, or Skeletool? 548
Newbie Posts: 9
« on: November 12, 2020, 04:23:22 PM »
Hello everyone! New member here. Wondering what type of SAK you guys would recommended with the above mentioned tools.
Sr. Member Posts: 319
Re: Recommendations to pair up with a Rebar, or Skeletool?
« Reply #1 on: November 12, 2020, 07:01:47 PM »
Hi, and welcome!  :)
This is really up to personal preference. Do you want a lot of overlapping functions, or maybe a light carry? Or do you want to try to be prepared for all eventualities?
When I combine tools I think about what to expect out of my day and which tools I might need for that. For example; I don’t have much need for a saw when I’m in a datacenter but I do use screwdrivers. When going into the woods a saw is a tool I like to have.
Generally speaking with a Rebar I would probably carry a Compact or Climber for the scissors and eyeglass screwdriver.
The Skeletool really depends on the kind of day, I would also take at least a Classic for the scissors, toothpick and tweezers. A Master Craftsman pairs up for a very complete package, you get scissors, a file, a saw and all the usual Victorinox tools.
No Life Club Posts: 3,782
« Reply #2 on: November 12, 2020, 07:17:40 PM »
Vick, you can reverse-engineer this kind of thing.  Maybe make a list of the tools you really want, and then go to Sak Wiki or smartknives.com and determine what SAK fits those needs.  For me, Victorinox scissors and an inline-phillips driver are a must.  But I also appreciate the magnifier, pen, pin, etc., so I like the Explorer Plus.  But it has a lot of redundancy with the Rebar, etc., but I'm okay with some redundancy.
No Life Club Posts: 3,210
« Reply #3 on: November 12, 2020, 08:06:55 PM »
Ranger / Master Craftsman  is good tool to pair with  Skeletool. With Rebar i would go with Pioneer X.
Only Tools Matters
Global Moderator He Who Has The Most Nuts, Wins! Posts: 51,232
« Reply #4 on: November 12, 2020, 09:25:43 PM »
Pioneer X with the Rebar  or Farmer X with the Skeletool.
Hero Member Posts: 640
« Reply #5 on: November 12, 2020, 09:31:26 PM »
All of the above suggestions are great. For me since I carry the same LMs I always pair them with Rambler because of the scissors and tweezers. For the tool overlap honestly the 58 mm SAKs is so accessible I end up using those tools rather than the LM. Which helps keep the LM blade sharp and clean (for food) and avoid scaring people when I take a tool out.
So the LM becomes either my back up or if I need something heavy duty.
I carry a Olight and Gerber shard too in case you want more choices.
If you frequently find yourself in a situation where you need 2 pliers (the other to hold a nut / bolt steady) you probably want to pair your LM with a SAK based pliers.
Absolutely No Life Club Posts: 5,300
« Reply #6 on: November 12, 2020, 10:19:13 PM »
...If you frequently find yourself in a situation where you need 2 pliers (the other to hold a nut / bolt steady) you probably want to pair your LM with a SAK based pliers.
I second that suggestion. And the SAK pliers are quite versatile as 'super tweezers'.
Global Moderator Just Bananas Posts: 63,188
« Reply #7 on: November 13, 2020, 01:49:06 AM »
I pair most everything with a Vic Executive  :salute: Great sized main blade, a good small blade, some very nice sized scissors, a really great small file, the lovely orange peeler, toothpick and tweezers :cheers:
Of course all the above suggestions are all tried and true as well ;) :tu:
« Reply #8 on: November 13, 2020, 01:53:27 AM »
You could also think about modding your own SAK :cheers: not near as hard as it sounds ;) I made a Master Ranger (pretty much a Champion without the fish scaler) that rides in my work backpack and is always there if needed :tu:
I also modded a Charge handle into a nice pocket knofe with a clip that I carry daily as well :D
The list can go on and on :whistle: you may have to try a few things and see what works best for you :tu:
Let us know how it goes :cheers:
Absolutely No Life Club Posts: 5,843
« Reply #9 on: November 13, 2020, 04:15:19 AM »
This was part of my thought.
Compact or Pioneer X with Rebar.  Those would also work in an urban environment with the Skeletool.
If more rural or use saw, then Farmer X or Huntsman.
If like a file, then Mountaineer or Ranger.
Global Moderator Absolute Zombie Club Posts: 23,666
« Reply #10 on: November 13, 2020, 06:36:10 AM »
Since I carry my Skeletool often enough and I like to pair it with my Champion.  I think the Mechanic would also be a great combo.  Whatever SAK you decide to carry with the Skeletool make sure it has scissors.
I don't carry the Rebar so I will defer to the suggestions already made.
No Life Club Posts: 1,284
« Reply #11 on: November 13, 2020, 05:28:05 PM »
As several other posts have suggested, the Compact is a good choice to pair with either of those (really any) multitools.
- Steve
Full Member Posts: 166
« Reply #12 on: November 29, 2020, 04:24:38 PM »
The leatherman micros fits the scissors and tiny screwdrivers part quite well.less redundancy too as it doesn't have anything that the rebar does etc.
No Life Club Posts: 4,646
« Reply #13 on: November 30, 2020, 02:01:23 AM »
Skeletool--basically anything. It's just a serrated knife that so happens to have light-duty, but capable pliers in my use. Thus, I pair it with almost all my SAKs that don't have pliers.  Rebar, basically anything with scissors. However, I often carry mine on its own. Does what I need. I usually throw a  Classic SD in my watch pocket if I need scissors. I prefer the Wenger Microlight Esquire, since it also has a small LED light good enough for small jobs.
March Goal: $300.00
Due Date: Mar 31
Total Receipts: $20.00
PayPal Fees: $1.34
Net Balance: $18.66
Below Goal: $281.34
 6%
March Donations
Page created in 0.038 seconds with 33 queries.
© 2018 Defender Web & Tool
