Victorinox laser pointer 740
Newbie Posts: 23
« on: November 30, 2020, 07:23:55 PM »
Hey guys, I’m looking for Victorinox sak with a laser pointer. I have a mini champ with one I bought around 2009/2010 that has one and  I think it was a custom, has been my daily carry since. The scale with the laser part has came a little loose and if I can find a replacement can I move the scale to a new mini champ?
No Life Club Posts: 2,855
Re: Victorinox laser pointer
« Reply #1 on: November 30, 2020, 09:12:57 PM »
I think the scale is the same as the typical lite module of the era. There are two main types, I think it uses the latter, modern type.
There aren’t many that come up for sale, so take care swapping the parts if you do.
Hero Member Posts: 566
« Reply #2 on: November 30, 2020, 09:26:33 PM »
They are similar, but not the same, due to the different dimensions of led/lasers modules and batteries
« Reply #3 on: November 30, 2020, 10:03:42 PM »
I think your Lite module is the early style I mention above. It has the ‘pop-out’ battery door. The modern Lites have a ‘swing-out’ door. Like your laser scale.
I have not taken apart my one laser to verify! But I have modded a few Lite modules and I am certain that there are at least two distinct types of those.
« Reply #4 on: November 30, 2020, 10:11:29 PM »
Seems, you're correct - old one used 1.5V battery (with 'pop-out' tray) and newer one with 3V battery
« Reply #5 on: November 30, 2020, 10:21:44 PM »
I pulled four samples for examples. Date on the pop out scale says ‘04-‘05. The laser scale says ‘08 and the other two are ‘13.
Newbie Posts: 23
« Reply #6 on: December 08, 2020, 03:00:14 PM »
Well guys, I was meaning where the scale is loose could I just take the whole thing off and put on a new knife or that too much?  Just Re- glue it.
« Reply #7 on: December 08, 2020, 08:36:21 PM »
I’d tend to want a new replacement scale since you’ve said they are already loose. But yes, you can glue it to another knife. I’d just use care with the glue because the laser unit is somewhat rare and valuable. A small amount in the holes should do it.
Newbie Posts: 23
« Reply #8 on: December 30, 2020, 04:50:35 AM »
Well it’s been my carried in my pocket for about 10 years now, the blades and stuff are worn bent used a lot. Since I’ve had no luck finding another with the laser, why I was asking.
« Reply #9 on: December 30, 2020, 05:09:23 PM »
I’m probably not being clear.
I’d re-use the laser module, and transfer it to a new Lite module scale and attach it to a new Minichamp knife without using glue.
Or if you buy a new Midnight Minichamp, carefully remove the Lite module and put your laser in it. If you do a good job with the removal, it’ll stay on just fine.
I hope that makes sense.
January Goal: $300.00
Due Date: Jan 31
Total Receipts: $41.47
PayPal Fees: $3.00
Net Balance: $38.47
Below Goal: $261.53
January Donations
SMF 2.0.18 | SMF © 2020, Simple Machines
Page created in 0.047 seconds with 52 queries.
© 2018 Defender Web & Tool
