I see at least two problems with this. First, the opener backspring is thinner than the Phillips layer. This can be solved by using two opener backsprings with spacers besides the Phillips/magnifier, but then the thickness advantage of the Yeoman over a regular Explorer becomes quite thin (see what I did here?). Second, the magnifier would protrude a lot in resting position. The old style magnifier is smaller so this may improve things a bit but I'm not sure it would be enough. I guess you'll have to try it to be sure, please let us know how this goes.
