To answer Q1, if you take out T&T fron the scales, soak in boiling water for 1 minute and then take them off, they can often be re-used.Sent from my LG-M200 using Tapatalk
Ah, nice. So does the knife (obviously, the plastic scales) need to be still hot when you get them off?
There is a link to the video. Skip about 3 mins inSent from my LG-M200 using Tapatalk
I've been wondering about just how difficult/expensive it is to refurbish, rebuild, and repair 91mm Vics. With the press-on scales and riveted construction, they're not designed to be easily disassembled. I would hate to have to buy new scales every time I wanted to take one apart. Kind of defeats the purpose, if the scales are in good shape, but a blade breaks, for instance.Maybe there's already a thread about all this. If so, if anyone wants to redirect me, have at it. :-)
So a few questions:1. Is it possible to reuse the existing scales if you take them off?
2. How do you disassemble and reassemble the metal parts of the knife after the scales are off?
3. Are there any ways to buy new scales at a reasonable price?
4. Other than donor knives, what options are available for getting replacement parts?
5. What options might there be for aftermarket parts, including special tools?
6. If you make your own wooden scales, how do you get them to attach?
7. Is awl this really worth it, or just get a new knife?
Hot soapy water and a toothbrush (don't use your own toothbrush--d'uh!--I borrow Mrs Nix's)…
And I also wonder if there's any real way to sharpen the saw blades.....
Depends how bad it is blunted. A fine square mini diamond file will probably be best for re-shaping if it’s really bad -might even get it sharp enough but the corner to a small sharpening stone should work for the final touch if not.
The Sharpmaker rods can be purchased separately from the kit, or in pairs. My main issue with the diamond files I tried is that they are short. And that lack of length makes it difficult to maintain consistent angles and pressure. Files also cut only one face at a time while the triangle stones ‘self-center’ and self-align while cutting two faces at a time.
Now I'm starting to wonder if there's a good way to touch up old dull-looking celidor scales. Some kind of turtle wax or something? Just trying to figure it out....Naturally, if I can get old dull scales to look better, I'll be better able to sell the used knives I get in the wholesale batches.
Um...yes. I assume that is only if the angle of the triangle stone matches the angle of the teeth....
