I just picked up an 84mm Climber in a lot of broken knives. The main blade is broken, but the rest is in great shape. I want to build an 84 mm Swisschamp if possible, if not at least a Craftsman. Does a Wenger file work on a Vic spring, or would I be better off cutting a 91mm file down? I may try and fit the Wenger scissors from the same donor and then replace the blade on the little Climber so I can keep it. I may go as far as cutting and reshaping a spring to make this dream come true.
Sent from my U307AS using Tapatalk
