Number me among those who has (until today) deemed the “multipurpose hook” nearly useless. I tried my Compact’s combo tool, but no dice. Then a thought occurred to me...would the hook work?Yes, it does. It works like it was made for the job.
Anything you could have done with any other tool or your bare hands, means you didnt need the hook.
Well, all kiddifying aside[...]
True enough! I used the hook recently to grab the thin cord of a pull-through cleaning cable in the breech on my air rifle - at times you just can’t grad it with your fingers!
All you need is imagination. I use the fish scaler a lot, the double horn tip can manage a lot of tasks without ruining and scratching it. I never used it on fish, as most of us.With the hook you can handle paracord, shoelaces (to tighten), rubberbands, wire (to twist), oil cans (the ones we use here, heavy and with wire handle that cuts your fingers), and a lot of other objects. Στάλθηκε από το MAR-LX1A μου χρησιμοποιώντας Tapatalk
Long live the hook!I just used it the other day to work loose a very tight knot in the drawstring of a pair of pants.
The hook is great. I just used mine to get into a new carton of milk that was sealed but missing its plastic pull tab: pen blade to make a slit to get the hook in; awl to punch a small hole to catch the tip of the hook; hook to pull out the seal cleanly. It worked so perfectly you can't even tell it was an improvised opening.
