111 Wednesday!!
us Offline Jim the Brave
  • Hardwood sawyer, and follower of Jesus Christ
Re: 111 Wednesday!!
Reply #90 on: March 26, 2021, 05:45:59 AM
SHARPAL sharpener and survival tool. Coarse and fine blade sharpeners, a rod for serrated blades and gut hooks and there's a fishhook sharpener on there as well. There's also a whistle and fire starter. Just in case. :)
I'm pretty sure that's what I need.  :D
This life is merely a staging ground for eternity. Are you preparing for the rest of forever?
Re: 111 Wednesday!!
Reply #91 on: March 26, 2021, 05:51:08 AM
My Hunter got some time in today. Sawed off a protruding ventilation sticker from a lumber stack.
Sak hard, y'all.
Re: 111 Wednesday!!
Reply #92 on: March 26, 2021, 02:06:26 PM
Hard to beat those saws!  :like:
Re: 111 Wednesday!!
Reply #93 on: March 26, 2021, 02:18:35 PM
That's the biggest reason I'm keeping the Hunter even after my [mine-mine-mine] SwissChamp arrives....along with the long main blade, the lock, and the serrated hook blade. All of which the SC does not have. The Ranger will probably be kicked to the curb.....
Re: 111 Wednesday!!
Reply #94 on: April 07, 2021, 04:13:30 PM
Bump!
us Offline FolderBeholder
Re: 111 Wednesday!!
Reply #95 on: April 07, 2021, 05:05:13 PM
Nice one Barry!  :cheers:
us Offline VICMAN
Re: 111 Wednesday!!
Reply #96 on: April 07, 2021, 07:23:14 PM
Re: 111 Wednesday!!
Reply #97 on: April 07, 2021, 09:47:39 PM
Thanks Lisa and Vicman!  :cheers:
Re: 111 Wednesday!!
Reply #98 on: April 08, 2021, 03:19:23 AM
Only one I have right now is the Hunter. I carry it a lot.
Re: 111 Wednesday!!
Reply #99 on: April 08, 2021, 04:41:21 AM
It's an excellent knife Jim.  I love that harness cutter.
Re: 111 Wednesday!!
Reply #100 on: April 08, 2021, 05:05:04 AM
 :o
It's actually for slicing open the belly of your game animal, to remove the bowels without puncturing them.... (That's what makes it a Hunter, not, oh, a rescue knife or something).  8)
But it could be used for cutting seat belts or other things, too, of course....
Re: 111 Wednesday!!
Reply #101 on: April 09, 2021, 04:22:14 AM
Thanks Jim!  Learned something new :tu:
Re: 111 Wednesday!!
Reply #102 on: April 09, 2021, 04:39:27 AM
Yeah, not to be too gross or anything, but when you kill an animal and you field dress it, you need to get the guts out fast so they don't spoil the meat. Especially in warmer weather, but even in colder weather. Plus, gutting the animal will leave 20-40% of the weight behind, making it easier to carry or drag out of the woods. So you would start with a very careful incision with a sharp pointed blade, in the center line of the belly area (depending on species, this may vary a little in practice, but for deer and other ruminants this is generally the case), then, if you have a gutting blade on you, you use it to slice a line up the belly. The blunt tip of the gutting blade allows it to slide under the skin without puncturing the entrails. If you do puncture the entrails, well, you potentially allow anything in them (partially processed food, you know, etc.) to come out all over the meat. And you want to avoid that if possible, because you want to keep your meat clean. Not to mention it's unpleasant.
The Victorinox Hunter features the curved, serrated blade, intended for this purpose. As I said before, it can also be used as rescue knife blade. But it isn't as long as a typical rescue blade, and in some cases, may not reach far enough under a seat belt to get to the other side in one pass.
Some hunting knives use a gut hook, an actual V-shaped hook, for the same gutting purpose. I don't remember seeing any Victorinox model with that type of gut hook, but I'm still learning about them, so I could be wrong. But the Hunter does not have one.
Re: 111 Wednesday!!
Reply #103 on: April 09, 2021, 04:42:31 AM
I've never gone hunting with this knife, but come to think of it, I think the reamer/awl would do nicely to make the initial hole, into which one would proceed to insert the gut hook. Never thought of that before....
Re: 111 Wednesday!!
Reply #104 on: April 14, 2021, 03:09:51 PM
Halfway through...111 Wednesday!
Re: 111 Wednesday!!
Reply #105 on: April 14, 2021, 06:41:23 PM
111 Wednesday coincided with the 30 SAKs in 30 days challenge, so I'll post this in both.  A side locking Adventurer that I've had for a long time.  It was used, and had a few dings in the edge, which I mostly got out of it.
Re: 111 Wednesday!!
Reply #106 on: April 14, 2021, 08:31:38 PM
Those are the best kind!  Mine are used too.  Nice pic!
Re: 111 Wednesday!!
Reply #107 on: April 14, 2021, 09:03:55 PM
Like a used car, you don't feel bad about the first dent.  :rofl:
Re: 111 Wednesday!!
Reply #108 on: April 14, 2021, 10:41:12 PM
Exactly!!  :D
Re: 111 Wednesday!!
Reply #109 on: April 15, 2021, 02:15:13 AM
Since I don't have any more 111's other than my Hunter, which I've posted a good bit about, I'll refrain from posting any pictures in this category today.  :cheers:
Re: 111 Wednesday!!
Reply #110 on: April 15, 2021, 02:21:03 AM
Keep posting Jim!  I only have a Hunter and the Workchamp.
us Offline kamakiri
Re: 111 Wednesday!!
Reply #111 on: April 15, 2021, 05:12:26 AM
Mine for today
Re: 111 Wednesday!!
Reply #112 on: April 15, 2021, 05:22:37 AM
 :like:  Very nice!
us Offline kamakiri
Re: 111 Wednesday!!
Reply #113 on: April 15, 2021, 08:33:01 AM
:like:  Very nice!
 :cheers: And thanks for the slide-lock recommendation when I asked in the WC comparison thread!  :tu:
Re: 111 Wednesday!!
Reply #114 on: April 15, 2021, 12:55:33 PM
 :cheers:. Absolutely my friend!  I wish all of mine were slide locks.  It's a terrific system.
Re: 111 Wednesday!!
Reply #115 on: April 16, 2021, 05:05:41 AM
Pretty much any 111 I keep will almost certainly be a slide locker. Not a fan of liner locks, and the Vic liner locks are especially obtuse.
za Offline WaynejG
Re: 111 Wednesday!!
Reply #116 on: April 21, 2021, 09:51:11 PM
How do you guys carry the 111mm? Normal sheath or drop it in your pocket?
us Offline toolguy
Re: 111 Wednesday!!
Reply #117 on: April 22, 2021, 12:34:37 AM
I carry mine in a belt sheath.
The top 111 is a Fireman,the side-lock version.
Compared to a Hunter,it may be a better tool than the Hunter due to its longer gutting/belt cutter blade.
Re: 111 Wednesday!!
Reply #118 on: April 22, 2021, 01:36:52 AM
I have one of the cloth Vic sheaths.  I only have 2 111s right now, and both of them ride in that sheath.  The mighty Workchamp definitely does!
us Offline ElevenBlade
Re: 111 Wednesday!!
Reply #119 on: April 22, 2021, 02:02:56 AM
I took the 111 out for a spin for a few days in the woods and boy am I glad I did. :ahhh
After our recent 30DC I decided that it was too much knife for me, but that was me just doing laps between work and home.  I'd become rather annoyed with the bottle opener, which was preventing me from quickly and easily accessing the innards of my bottles without putting up a fight
But I've been since been reacquainted with the OHO blade and put it to good use.  This will be my go-to for outdoor adventures for the foreseeable future. Even though its more blade than I normally need, with cold slippery hands, the 111 was better than the 93.  and that's an advantage.
Total Receipts: $21.00
PayPal Fees: $1.42
Net Balance: $19.58
Below Goal: $280.42
