Nope. I think that Ciber Compact is it! Great setup!
The little Manager is a good option because he’s got everything I need... but the size of the blade is not big enough. Any toughts? Am I missing a knife?
Out of those three I would pick the Cyber Compact. That screwdriver is just awesome
My first vote is to go with the Climber...as it seems it has everything you want based on your list.You didn't mention needing a magnifying glass.Since you like the Manager, you could always carry it along with a single bladed knife like an Opinel, Douk-Douk, Spyderco.The solution it seems is a Mega Manager (Manager with larger blade)...wouldn't that be dreamy!
The CyberCompact is really nice. Looks like it ticks all the boxes. It also adds quite a bit of function having the extra bits. Question. Do you use those extra bits? If yes then you've got your EDC. If no then Yeoman mod. I am not a fan of changing the can opener
There he is again with his Ciber SAKs
I keep forgetting you awl misspell it here...
You reject our reality and substitute your own!
That’s where I’m at right now... I need: - Phillips in-line screwdriver - scissors- Nail file- Blade - Bottle opener- corkscrew - ballpoint penPocket size for a right front jean pocket... So 3 layers (4 for the cybercompactool) is the max. The 3 winners are:- Compact cybertool (mod)- Yeoman (mod) with the Phillips/magnifier layer in the middle position- Climber with the can opener modded as a Phillips screwdriver (Both have the nail file in the hook)
The Cyber-Compact is great!
