I disagree with Micky. Whilst he is right that its takes time to set up, I have found it is better than the sharpmaker as it removes any deviation of angle that the sharpmaker can allow, if the user ain't up to much.Its a good basic system thats expandable with different rods and cheaper too
Quote from: Flash on January 17, 2009, 07:55:32 PMI disagree with Micky. Whilst he is right that its takes time to set up, I have found it is better than the sharpmaker as it removes any deviation of angle that the sharpmaker can allow, if the user ain't up to much.Its a good basic system thats expandable with different rods and cheaper too Didn't know you had a Sharpmaker as well.I haven't tried a Lansky but even someone as useless as me can put on a decent edge with a Sharpmaker.
Quote from: Flash on January 17, 2009, 07:55:32 PMI disagree with Micky. Whilst he is right that its takes time to set up, I have found it is better than the sharpmaker as it removes any deviation of angle that the sharpmaker can allow, if the user ain't up to much.Its a good basic system thats expandable with different rods and cheaper too While that's true, I doubt anyone would have much trouble maintaining a consistant vertical angle
Quote from: Micky d on January 17, 2009, 10:17:34 PMQuote from: Flash on January 17, 2009, 07:55:32 PMI disagree with Micky. Whilst he is right that its takes time to set up, I have found it is better than the sharpmaker as it removes any deviation of angle that the sharpmaker can allow, if the user ain't up to much.Its a good basic system thats expandable with different rods and cheaper too While that's true, I doubt anyone would have much trouble maintaining a consistant vertical angle Tell you what....at the meet up I will bring my Lansky....someone bring a sharpmaker. There should be some dull blades and we can dick around and compare results.About that vertical angle.....I will test you (maybe after a few drinks )
I'm keen to try Flash's at the meet.
Quote from: Benner on January 21, 2009, 08:46:14 PM I'm keen to try Flash's at the meet.I hope you mean the Lansky
Quote from: Flash on January 21, 2009, 08:48:49 PMQuote from: Benner on January 21, 2009, 08:46:14 PM I'm keen to try Flash's at the meet.I hope you mean the Lansky You know what I mean.
