Did you heat them up to break the loctite ? also only one side turns on the tool side of the Rebar. The knife side is captive.
I did not know that, thanks. The side of the tool I am working on is the one with the saw and serrated blade.
I was sent a link to buy a specialty tool from Loki, but when I look at those tools, I do not see how they would work with the way the one end of the Rebar is made.
I finally made some progress with my Rebar using pliers from a Gerber Suspension NXT! At first, I made the tools a bit too loose, and I had a heck of a time tightening them back up a little. It is not perfect, and never will be, but I think I got it the way I want it, or as good as it is going to get. I wish Leatherman would modernize some of their older tools. I have off brand name Chinese multi's that open a lot more smoothly, do not clump, and close a lot smoother than this Rebar. They are also a lot easier to maintain. Anyhow, thanks for all the help folks!
