Thanks, ST! Lanyards are not only functional, for those who like them. But also, make a design statement, as you pointed-out. The choice in paracord should at least jell with the knife's scales. I swapped-out a new cord today on my Scout.(Image removed from quote.)(Image removed from quote.)(Image removed from quote.)
Here is the lanyard on my Al Mar 5th Special Forces [Abn.] bowie:(Image removed from quote.)
Here's my other Off Grid Rapid Fire(Image removed from quote.)
I just finnished this one to the good old EDC Outrider black.This samurai bead arrived some days ago together with a new (and bigger) molle pouch for my belt EDC, I was lazy, but seeing this thread gave the impulse to do this one. It is a little bit lenghty for my standards, but I do not want the bead bumping in the SAK, for the sake of the bead, for the SAK is regrettably scratched. This Outrider is my EDC SAK for more than 15 years, I think. I plan to put this fellow to rest in the collection if and when a OH Outrider is available. If not, I keep on using the combination of two SAKs that I use sometimes, or buy a new Outrider, change the scales for this scratched one and keep on truckin'. Anyway, I really liked this lanyard!!!
Superb color choice. Royal blue to Purple with black scales exudes a mixture of formality (black) and some royal panache (purple). Also a hint of nocturnal daring. The interwoven pink creates an element of surprise. May I suggest you give some thought to using a flo pen marker in a hue of red as close to the red back ground of the cross as possible on the pink. If the pink of the lanyard were darkened to a red resonating with the scales logo, I think everything would come together even more decisively. Ideally you could find a dark red paracord and retie the lanyard, but you have tied such a splendidly tight lanyard I hate to see you untie it. Hence, a careful application of a red flow pen to the pink cord might darken it just enough. That said, it is splendid just as it is, also. Is it a sliding knot? I have seen some tied so as to slide and tighten on a wrist. Fine knife, too! I have a 111mm work Champ in red scales and like it a lot. I too wish for OHO on it.
Here's one of my MiniChamps with scales from Remade Knives. Orange paracord with simple snake knots and what better goes with an 8 blade knife than an 8 armed bead.
I bought the same octopus bead after seeing yours back when, and it was a little bigger than I expected so I decided against using it on a pocket knife, and it has languished for over a year, but I've added it to my new Brisa EnZo Necker 70 which I will start carrying as my EDC fixed blade as soon as I'm not in a monthly challenge.
