Assembly Cadet Alox
AFG · 14 · 962
Offline AFG
Assembly Cadet Alox
on: March 29, 2021, 02:59:13 PM
Hi, I'm new in the Forum and I would like to answer to the experts about the steps for assembly the Cadet with my new Ti scales and pivot screws. Really I'm trying to do it and for the moment I' can't because I don't know if I must to install the center pivot first, last, compress the springs, install the springs last,....
Really I need advices for assembly the cadet, It's very hard for me.
Thank you
Alberto
Re: Assembly Cadet Alox
Reply #1 on: March 29, 2021, 05:46:02 PM
Thank you
Alberto
Hi there! Welcome aboard!
 :cheers: :salute:
Sorry, can't help you but I'm sure someone more knowledgeable will soon come along with some tips.
Offline AFG
Reply #2 on: March 29, 2021, 05:47:54 PM
Thanks man!
00 Offline tom57
Reply #3 on: March 29, 2021, 06:24:48 PM
I dont have any experience with aftermarket scales and screws but I imagine its very similar to a brass pinned build. I assume you have 6 screws and 3 pivot barrels?
Set the 3 pivots on one scale and lay it flat on a work surface, then add the tools and back spring layer by layer ie blade layer then openers followed by the other titanium scale.
Im sure someone will be along with first hand experience.
Good luck!
Offline AFG
Reply #4 on: March 29, 2021, 07:46:16 PM
I was trying as you explain but when I'm trying to install the second scale it's impossible to put the 3 pivot in their holes (scale), only 2 pivots.
00 Offline tom57
Reply #5 on: March 29, 2021, 09:56:43 PM
I think some photos would be really useful for when the experts chime in.
Im sure you'll manage with the help from the guys on here. I wonder if this post may be of any use?
https://forum.multitool.org/index.php?topic=73215.0
Offline AFG
Reply #6 on: March 29, 2021, 10:13:29 PM
Thank you for the post, very interesting, but really I need to know the tip for install the second scale when all the tools are installed.
Offline ComboTool
Reply #7 on: March 29, 2021, 10:23:35 PM
You should compress the springs in a vice. The jaws should be covered in soft material so as to not damage the scales. Assemble your knife and attach the second scale to the two end pivots (tighten the screws lightly). Open the tools so that one jaw of the vice presses the scales while the other presses the backspring. At some point the third pivot will line up with the hole in the scale and you can add the last screw.
Offline AFG
Reply #8 on: March 29, 2021, 10:33:18 PM
I understand you, ComboTool, very helpful!, thank you very much.
Then I must to install all the layers with the central pivot installed and the springs with tension and after put the knife on the vice?
Offline ComboTool
Reply #9 on: March 29, 2021, 10:47:42 PM
Yes, exactly. And one last piece of advice: at the point where everything lines up, the tension on the center pivot is released and it may fall. Putting some tape on the first scale will keep it in place for the duration of the procedure.
Offline AFG
Reply #10 on: March 29, 2021, 11:22:50 PM
I will try your method, excellent advices!!!. Thank you very much.
00 Offline tom57
Reply #11 on: March 31, 2021, 07:38:31 PM
If you're still in need of any help I saw this on Instagram today which shows the method as described above
Offline AFG
Reply #12 on: April 01, 2021, 12:53:19 PM
Thank you, very helpful!.
Reply #13 on: April 01, 2021, 12:53:52 PM
Thanks for sharing!
 :cheers: :tu:
