This looks fantastic. I’m really glad I backed you on Kickstarter. Will you have any extra? I’d probably want two of them. Sent from my iPhone using Tapatalk
GOAT, you need to re- up your paid subscription if you want to continue to have links to your product. I sent you messages a while back but you didn't respond. We can't allow you to advertise for free on the forum as it's not fair to other paying members.
A closeup view of the bit holder shows it can hold a double-ended bit. If you freeze-frame the vid toward the start as the tool is flipped over, you will see a larger phillips bit in the holder and a smaller phillips seen through the arrow-shaped hole in the bit holder on the opposite end. Good feature.
Here is the latest video showing off their new titanium scales with laser-cut logo and hobby blade with replaceable blade, So nice!!!!Note: The video thumbnail also shows their beautiful and interchangeable brass scales! Awesome!https://www.youtube.com/watch?v=lFzYC9OWMbQ
The torsional (twisting) forces generated (in the multitool handle) while using the bit driver are 'channeled' through the slimmed-down thumb cutout portion of the handle which contains the bit driver. Question: Will this result in excess flexing of the multitool handle while tightening down a screw?The same rationale would apply to the multitool handle which contains the large flat blade screwdriver. This may be a good practical reason to attach the optional titanium scales for added rigidity and strength.
Interesting take... the twist would be counteracted somehow by the pivot heads not allowing too much axial give, but whether that's enough?
Just threw one of the multi-tools in a vice with a 1/4" hex in the bit driver. Connected a 1/4" socket to my torque wrench, started wrenching, and it easily got over 80in/lbs. The handle holding the bit twists slightly, but goes right back to where it was. Out of curiosity, I did the same test with my old Wave and it acted the same.
