Convert serrated 111mm to non serrated 277
Newbie Posts: 19
« on: April 14, 2021, 03:14:00 PM »
I bought a 111mm one hand open blade SAK, which I like except for one thing. I DON"T LIKE SERRATED BLADES
Can I sand or grind the blade down to remove the serrations then sharpen as a normal blade?
I know the blade shape or profile will be slightly altered but thats OK by me
Now next question how to do it. Sandpaper then  stone for final sharpening? Would a file work to remove serrations?
Thanks in advance for any suggestions
No Life Club Posts: 4,300
Re: Convert serrated 111mm to non serrated
« Reply #1 on: April 14, 2021, 08:08:23 PM »
Yea you can. I have a GAK that this procedure has been done. Done before I bought it.
I can’t tell you how, but any experienced knife sharpener can do it.
Newbie Posts: 19
« Reply #2 on: April 14, 2021, 08:17:45 PM »
Thanks zrxoa1
That's what I thought
There is a little bit of info online but nothing great
No Life Club Posts: 2,314
« Reply #3 on: April 15, 2021, 08:01:06 PM »
I love serrated blades, but if I were to try to remove the serrations, I’d go with a coarse diamond plate to cut them down. Like DMT ‘blue’ at least.
I think the main thing to decide is if you are going to keep the blade a 1-sided chisel grind, or a symmetrical one.
Hero Member Posts: 929
« Reply #4 on: April 16, 2021, 09:31:37 AM »
I did exactly this to my OHO GAK a little while ago: ground out the partial serration with a 100grit diamond plate, moving to 200-400-600, I also made it a convential rather than chisel grind. There's a hint of serration left, but that's purely because I weighed up fixing it vs the additional wear on my stone, it doesn't actually meat the edge, so just looks a little funky. Here's some picks, I used a Wicked Edge to do it, any guided angle sharpener would make this pretty trivial if time consuming:
Become the night and join us for the Batman Challenge in January!
Total Receipts: $79.60
PayPal Fees: $5.65
Net Balance: $73.95
Below Goal: $226.05
25%
Page created in 0.029 seconds with 33 queries.
© 2018 Defender Web & Tool
