Leatherman Bond Owners Club
Poncho65 · 1008 · 95401
Re: Leatherman Bond Owners Club
Reply #270 on: May 23, 2021, 01:18:09 AM
That green reflecting off the Bond is beautiful.
Reply #271 on: May 23, 2021, 02:01:19 AM
:agree:  They need to make a tool with that green.
Reply #273 on: May 23, 2021, 04:59:13 AM
Thanks peeps :hatsoff: the green was off the surrounding leaves  :cheers:
nl Offline nitram
Reply #274 on: May 23, 2021, 01:22:07 PM
It's almost been a week now, I really like it. It's reassuringly old school   :multi:
nz Offline Syncop8r
Reply #275 on: May 23, 2021, 01:24:08 PM
Clearly its effect on you is amplifying.
nl Offline nitram
Reply #276 on: May 23, 2021, 02:20:53 PM
It goes up to 11  ;)
Reply #277 on: May 23, 2021, 03:48:06 PM
 :iagree: :rofl:
Great pic,  nitram :like:
nl Offline nitram
Reply #278 on: May 23, 2021, 04:06:14 PM
Thank you Poncho! I stole your Sharpie trick, it does make the letters pop out nicely  :hatsoff:
Reply #279 on: May 23, 2021, 04:12:45 PM
Glad to be of service  :hatsoff: :D
It is a simple trick that makes a big difference  :ahhh sometimes it lasts for a long time and sometimes it wears away kinds fast but at least it is easy to redo :tu:
Reply #280 on: May 24, 2021, 01:35:08 PM
Couple pics  :cheers:
Reply #281 on: May 24, 2021, 02:37:09 PM
Nice pics buddy !
Reply #282 on: May 24, 2021, 02:38:47 PM
I'm tempted to remove the blade and add a saw in it's place   :think:
spam Offline Happy Gilmore
Reply #283 on: May 24, 2021, 04:59:40 PM
that would be sick!
my modified bond, and I love it.
Reply #284 on: May 24, 2021, 05:05:29 PM
Thanks Steve :hatsoff: I believe as much as you have another blade handy then that would be a great idea  :tu: :like:
Nice modding, Max :o :like:
Is the side with the scissors not a bit tight :think: I couldn't get the scissors in without it binding some  ??? Can we get a pic showing how all the tools are with a top down view  :think: :cheers:
za Offline Max Stone
Reply #285 on: May 24, 2021, 05:41:43 PM
No real issues - the file, scissors, flat and lifter clump no worse than the original when lifting any of these out, so it's just a case of pushing back what you don't need. I did add a very thin brass washer on each side of the saw, so that the saw and blade lift independently and don't pull the rest of the tools out behind them. Cap lifter needed a bit of work to clear the pliers, other than that, all tools stock.
Reply #286 on: May 24, 2021, 05:50:48 PM
The Rebar I can fit all of that (still a sweet setup :like: ) the Bond won't fit as much though :dunno: :D :cheers:
us Offline NutSAK
Reply #287 on: May 24, 2021, 11:57:22 PM
2. Add a tiny bit of material to the fold-over area at the knife blade top end to create a little retention notch, like the Pulse had it...
What do you guys think?
None of the Pulses I own have any sort of retention notch.  I don't believe that fold-over area is supposed to contact anything. It doesn't on my examples.
- Terry
Reply #288 on: May 25, 2021, 01:34:23 AM
I need to go and check my 2 :think: Not sure but I don't believe mine had that either :dunno:
Reply #289 on: May 25, 2021, 01:52:39 AM
Nothing on my Pulse  :dunno:
Reply #290 on: May 25, 2021, 03:45:32 AM
Nothing on either of mine :dunno:
Reply #292 on: May 25, 2021, 12:16:47 PM
I didn't even pay attention to the LM Stone :rofl: :like:
Reply #293 on: May 25, 2021, 12:41:05 PM
I'm glad someone noticed.  :D
*in fairness it doesn't stand out much against the background.
nz Offline Syncop8r
Reply #294 on: May 25, 2021, 01:50:56 PM
Are you OK Steve?
Reply #295 on: May 25, 2021, 06:24:52 PM
will do later today. yea, I ended up shuffling some tools in order for it to go together much better with out the frame bending.
us Offline Deathtakeslast
Reply #296 on: May 25, 2021, 06:27:51 PM
that would be sick!
do they sale a wrench that allows this
Reply #297 on: May 25, 2021, 06:58:25 PM
Yes, the loki wrenches (as we call them here  ;) ) are sold by member loki_mobile down in the Multitools for Sale subforum :salute: He sales different versions of these and also sells things on ebay :cheers: I think forum members get things just a bit cheaper than his eBay listing as well :think:
I have a couple of the 4 way wrenches that fit 4 different sizes of the LM knurled screws and they work great for tightening, loosening and taking apart just about all LM that use that type of fastener :like:
Reply #298 on: May 26, 2021, 11:31:05 PM
Offline dmattaponi
Reply #299 on: May 27, 2021, 06:20:09 PM
Hadn’t heard of the Bond until I saw a thread about it here, and decided to take a chance on it in spite of the blade issue so many are commenting on.  I really like the old school multi tools much better than the new tools.  I’ve never wanted to have a multitool replace my pocket knife, and from the time I first heard about them, I’ve thought of them as a small toolbox in a pocket.  I like my tool boxes to be made of good old fashioned steel with a lid that closes over my tools.  My Bond came in the mail today.  First impressions are good.  Nice lighter weight pocket tool with an array of basic (but most used tools).  I’ve got a pocket clip ordered.  The blade issue everyone seems to be talking about in Bond is present on my example but to be honest It doesn’t seem likely to lift up on its own with normal use (at least on my example).  I even bounced and shook it around trying to get it to lift up and out, but it stayed put.  I can lift it up and out a little without resistance with my finger, but it stays in the liner unless I manipulate it intentionally.  I could definitely see the Bond as being the answer to a twenty something year quest for a pocketable “full-power” multitool.  As for the sheaths, I like them both.  I’ll probably keep it in the leather because it’s a good match for a new rendition of an old tool, but if I were going to pick one for everyday use, I’d probably go with the nylon for lower maintenance.
« Last Edit: May 27, 2021, 06:38:25 PM by dmattaponi »
Total Receipts: $21.00
PayPal Fees: $1.42
Net Balance: $19.58
Below Goal: $280.42
