Leatherman Bond Owners Club
Poncho65 · 783 · 47194
Re: Leatherman Bond Owners Club
Reply #60 on: May 15, 2021, 12:33:51 AM
The tool itself :dd:
First impressions are very good :salute: It is very PST like but a bit beefier 8)
I just so happen to have a few similar tools to compare it by :D
Here is my similar tools in order of release :cheers:
The PST, PST II,  Pulse, Rebar and Bond :salute:
You can definitely see the similarities in the DNA strand :D You can also see that LM have come full circle with the PST in its evolution as well :o :like:
I left the PST II out in some of the pics since the PST and it have the exact same chasis :cheers:
The thickness of the Bond is very similar to the PST, it is much slimmer than both the Rebar and the Pulse :o Not much thicker than a PST :ahhh
Rebar to the left and Bond on the right  :tu:
Pulse in the left and Bond on the right :tu:
PST on the left and Bond on the right :tu:
On to handle splay :cheers: The Rebar is known to have a larger splay the the PST and I am glad to report that the Bond has less splay than the Rebar and is very similar to a PST I'm this aspect as well  :salute:
Rebar on the left and Bond on the right :tu:
The PST and Bond are so similar and that makes me happy :like:
The toolset is the same with both but the Bond has updated versions of them :like:
:nanadance:          :nanadance:
« Last Edit: May 15, 2021, 12:49:08 AM by Poncho65 »
Reply #61 on: May 15, 2021, 01:19:22 AM
 :like: :tu:
Reply #62 on: May 15, 2021, 01:33:22 AM
 :hatsoff:
Reply #63 on: May 15, 2021, 01:33:53 AM
Does raise the excitement for you a bit doesn't it :D
Reply #64 on: May 15, 2021, 01:51:28 AM
 :ahhh
Reply #65 on: May 15, 2021, 02:22:11 AM
Awesome pics and walkthrough mate.  :salute:  No doubt there is one of these in my near future.
Reply #66 on: May 15, 2021, 02:24:35 AM
Thanks Gareth  :hatsoff: It really is a really good and respectful PST replacement  :salute: :like:
us Offline gregpost
Reply #67 on: May 15, 2021, 02:34:11 AM
That was a fantastic write up/comparison Poncho65.
I think I'll skip the Bond unless I see it at retail but it looks like it answers a lot of concerns with modern Leatherman that fans of the old school tools missed.
« Last Edit: May 15, 2021, 02:56:37 AM by gregpost »
Reply #68 on: May 15, 2021, 03:31:01 AM
Thanks greg :hatsoff: It ticks a lot of boxes for people that love the old school tools for sure :salute:
Reply #69 on: May 15, 2021, 03:31:09 AM
 >:D
Reply #70 on: May 15, 2021, 03:41:15 AM
I actually tried scissors (from Wave/Charge/Blast/Fuse) and diamond file (from a PST II for those taking notes) in the Bond but after taking the lanyard out and adding the scissors I found it to bind the tool a bit and didn't make a great experience for me :ahhh I may try to reorder the tools a bit later and see if I can get it to work more to my liking but for now just the file is staying :cheers:
After getting it apart I compared the 2 files to see what I had to take off with a Dremel :think: you can barely see it but the diamond file is under the Bond file  :salute:
The 2 side by side :cheers:
Surprisingly I only had to cut a tiny bit off at the locking notch because the bigger cut out that is close to the pivot is only there because the Rebars locking tabs are in its way :cheers: The Bond has no such thing in the way and the file fit fairly well after just a tiny bit off the locking notch  :woohoo:
After getting it in though I noticed that the fingernail pull is on the wrong side :facepalm: so I added one to the other side ;)
A bit of refinement in the locking notch and perhaps a little more time on the nail pull would make this much better but I will save that for another day because it works as is and I will perhaps try the refinements if I take it back apart for scissors in the future :salute:
us Offline 4.19.93Waco
Reply #71 on: May 15, 2021, 04:38:37 AM
Very nice work Poncho! I'll have to do some comparison shots with my PST, my Kick, and the Bond when I get mine.
Reply #72 on: May 15, 2021, 04:47:57 AM
Mine arrived today. I'll get the photos up tomorrow.
Reply #73 on: May 15, 2021, 06:10:59 AM
Thanks Waco :hatsoff:
Can't wait for you both to get one in hand :ahhh :like:
wales Offline Gavin Jones
Reply #74 on: May 15, 2021, 08:23:46 AM
Received mine today.......,modified within the first 10mins🙄.
So far I’m impressed.
Nice size and weight (between a Rebar and Pulse in size).
Suits my needs as a work EDC.
Don’t need scissors, as I have a style CS on my keys and I also carry a Raptor now and then.
I also have no need for an awl.
Pocket clip fitted(from old P2).
Awl and 3D Phillips removed.
Bit driver and micro screwdriver exchanger fitted. Plus fitted locking washers/shims between every tool.
Topped it off with my old PST leather sheath(which fits perfectly with the clip fitted as well).
Does the bit holder need any modifications to fit the Bond?
au Offline pietervn
Reply #75 on: May 15, 2021, 08:24:53 AM
Nice pics and write-up Poncho
I'm secretly hoping for a PST II update too. The files in them are just fantastic!!! Is the Bond easier on the hands when squeezing hard on the pliers?
Cheers, Pete
nl Offline nitram
Reply #76 on: May 15, 2021, 08:25:48 AM
Thank you Poncho, that’s great to see. Good size and less splay. You just sold me on the Bond  :hatsoff:
ph Offline an0nemus
  • I Tool Therefore I Am
Reply #77 on: May 15, 2021, 08:38:18 AM
Excellent comparison, Poncho!  :tu:  What's the weight difference between the Bond and the Rebar?
scotland Offline Olives666
Reply #78 on: May 15, 2021, 12:01:03 PM
No, fits straight in. It’s the same thickness as the 3D Phillips.
Reply #79 on: May 15, 2021, 12:11:05 PM
Can I just take my Rebars to a distributor so they can drill and tap them for pocket clips? ::)
Reply #80 on: May 15, 2021, 01:53:34 PM
Sigh. Got to wait patiently to get my copy in....got to wait patiently....just got to wait patiently...why am I failing at this?  :think:  :rofl:
00 Offline Dutch_Tooler
Reply #81 on: May 15, 2021, 02:53:13 PM
Just reading this - thanks for the great write-ups Olives666 and Ponch  :salute:
I think I'll order one soon. It so happens that I was preparing for some small future mods and had stocked up on pocket clips >:D
Cheers!
Dutch_Tooler
Reply #82 on: May 15, 2021, 03:33:17 PM
Thanks pieter, nitram, an0n and DT :hatsoff:
I also hope that they make a refreshed PST II :salute: :like: I haven't really had a chance to test it yet, so I can't comment on the comfort of the handles but seeing that it only has one of the cut outs that the Rebar does, I would say it is a bit more comfortable than that :salute:
That would be great if they would do that :o who knows, if enough people email them and question them then you never know :salute: :like:
I think Maxlvledc weighed them but I don't have anything to weigh the difference  :think: I think the Bond is around 6oz maybe a little under and the Rebar is about 6.7oz.
:dd: :popcorn: :like:
Reply #83 on: May 15, 2021, 03:34:16 PM
:shrug:
 >:D
Reply #84 on: May 15, 2021, 03:43:52 PM
While we are at it, we might as well get the datecodes of these as people get them :cheers:
Mine is 1020 and 0121 :woohoo:
Reply #85 on: May 15, 2021, 04:33:10 PM
I wonder why date codes on these but not the Rebar considering it's basically the same frame.    :dunno:
us Offline Steelej1976
Reply #86 on: May 15, 2021, 04:46:47 PM
Well thanks to Poncho and Powernoodle (Multitool Enablers) pictures I think I am going to buy the Bond.  I had been debating the Rebar for a while now but the Bond seems more my speed.  I don't care for replaceable wire cutters because I feel they eat into the plier portion too much.  Just call me Bond, Leatherman Bond.   :multi:
Reply #87 on: May 15, 2021, 06:32:30 PM
Perhaps they have a better system for putting them on now :think:
Reply #88 on: May 15, 2021, 06:34:07 PM
Reply #89 on: May 15, 2021, 06:37:13 PM
December Goal: $300.00
Due Date: Dec 31
Total Receipts: $172.67
PayPal Fees: $9.54
Net Balance: $163.13
Below Goal: $136.87
54%
December Donations
