Bibury 21 in 1
HyperTough Electrician Multi Tool
The HyperTough has a decent wire stripper head, but the rest of the tools are somewhat smurfy.
The Bibury 21 in 1 has a decent set of tools, none of them are inside opening, and its plier head and the HyperTough wire stripper head are approximately the same size.
Fellow member Hvac budget posted a review of the HyperTough in the Cheap and Cheerful subforum a couple of days ago and mentioned his desire of installing the wire stripper onto the Bibury. Since I have both MTs and have delusions of being a modder, I decided that I would attempt this modification:
No, this is not a Bear & Son 155ELBeing that this is my first attempt at modding, it was an experience
My grinding work looks crude. I still need to work on the spacers. The handles don't quite line up when closed. But it does work.
One thing different I would do is use a different donor wire stripper.The HyperTough cutting edge, while greater in length than the Bear 155EL, is too short to efficiently cut Romex wire.
