Angler + 5 Layer varient
Offline Muckum
  • New User
on: June 22, 2021, 04:38:08 AM
Through research I have concluded that I have what seems to be a much older model of an Angler plus 5 layer variant.  It’s about 83 mm in length and includes a saw and file. I’m trying to find some replacement sides for it. Any suggestions?
us Offline Boonies
Re: Angler + 5 Layer varient
Reply #1 on: June 24, 2021, 03:46:50 AM
Hi Muckum.....sounds like you may have a small Master Craftsman.  As far as I know it’s the only 84mm variant that has both the wood saw and metal file/metal saw.
https://www.sakwiki.com/tiki-index.php?page=Victorinox+Master+Craftsman+Small
84mm scales can be found on eBay, just have to make sure you have the cutout on the back scale.
Nice model if that’s what you have, very desirable...... :cheers:
au Offline Huntsman
Reply #2 on: June 30, 2021, 09:40:15 AM
So does it have the fish scaler? - Pretty unusual in an 84mm - Otherwise I agree with Boonies
As to your question:
Regular 84mm scales should fit - You can try ebay or searching online - But 84mm scales are not so common as 91mm for replacement.
So you could buy any current 84mm model and use those scales (fitting may depending on the age) - I guess the Waiter is the cheapest
Ooops - Just seen Boonies comment about the 84mm scales being available :tu:
Although as Boonie says if you do have a Small Master Craftsman - It's a more uncommon model - So you may want to keep as is.
If you just like users - Go for it!!
PS. You'll find you get a more useful response if you give your post a more meaningful title.
Make it summarise what you are asking and action orientated!! eg.
Where can i get replacement scales for an old 83mm (or 84mm) five layet Angler?
Just the name of a model does not tell us much!
« Last Edit: June 30, 2021, 09:45:44 AM by Huntsman »
Reply #3 on: June 30, 2021, 06:59:29 PM
us Offline Jim the Brave
  • Hardwood sawyer, and follower of Jesus Christ
Reply #4 on: July 01, 2021, 12:21:27 AM
Yes....does it have a scaler?
 :worthless:
This life is merely a staging ground for eternity. Are you preparing for the rest of forever?
