Great first build Steve - always the most challenging, but it's the best confidence builder and your build should look great (can we see a pic?) One suggestion I can make. To help with the initial peening, where you had trouble holding it in a vice, what I do is sandwich the brass rod (already cut) between two layers of hardboard (that thin, highly-compressed stuff). I position the bottom of the pin about halfway down the sandwich, and then put this in my vice really tight so that the hardboard is compressed around the rod. This really locks the rod, stabilizes it from bending, protects it from damage, and you can peen away. Another little tip; add a very small chamfer to the edge of the rod before peening. While this sounds counter-productive (in that the whole objective is to spread the head), this actually helps to direct the force into the head and you get a more stable, neat-looking peen.
And I'm done! Scales are on and I've oiled my new SAK.Introducing ... the Deluxe Explorer!Max Stone named his the Detective. But I'm liking Deluxe Explorer as that matches Victorinox's naming - the Deluxe Tinker is the Super Tinker + pliers.Though technically mine is a Deluxe Explorer Plus because of the scales, but that name doesn't really roll off the tongue. This first mod has been fun and interesting. And not too difficult. I'd almost say the hardest part was getting the parts. Thanks to all the great tips in this forum, particularly in the Mod Squad section, the actual work was pretty easy.Now I get to enjoy it!
Great job! Thanks for the detailed write-up and photos. Definitely a great toolset
