Welcome to Multitool.org!I can't think of any direct fit parts that would go in a Keybar, and insee Keysmart doesn't have any either. I believe their plan is to try and conserve space as much as possible, and bit drivers are bulky- even the flat Leatherman ones.I think your best bet might be to either install the Keybar screwdrivers and make do with that, see if you can find a Leatherman flat driver and try to make that fit, or see if you can locate the small bit driver from a Victorinox Cybertool, and try to make that fit.Def
Wanting a t6 and t8 capable bit driver to maintain knives on the go!I've thought about both the Leatherman bit holder and the SAK one just not sure how they'll lock into place! Sorry for being difficult
If all you're looking for is a T6/T8 you could use a leatherman bit, drill a hole in the middle and throw it on a split ring. You can torgue it with the split ring (for most knives that should be adequate unless you're breaking a lot of red loctite, in which case you should use a real driver and heat anyway). It wouldn't be inside of the Keybar, but it'd be so low profile it could hang off it where the key fob attackment is.
I've thought about that. I'm looking to have a secondary knife as well which made me think Keybar! And a possible Bit driver
Do you already use one for your keys? If you're wanting a back up knife too, then something like a half MT (I'm sure Poncho will be along to link his envy inducing half Charge) might be a good fit?
Sweet Charge Knife
