First thing I'd ask is if you are setting up a "base" camp or are you moving around and carrying everything with you?
You can split logs using this technique with a folding saw But chopping with an axe is a lot of fun and a good workout It all depends on the size of wood you are splitting.Sent fra min M2002J9G via Tapatalk
Indeed, there's a certain risk with shorter handles, which I hope can be lessened with gloves and a lanyard. I thought of a folding saw, but I'm not sure to what extent it can split wood, which seems to be what I need to do to get better fires going. I like the Fiskars and Gerber hatchets. Are they just as good as the "splitting" heads?
This is a good way to use a lighter hatchet to split larger wood. Happens to be with a Fiskars X7.
The one thing I'd avoid are these flat headed type thing;(Image removed from quote.)With basically no "wedge" shape to the head you'll have a very tough time splitting anything. Sadly the Mora camp axe falls into this category IIRC. Not tried one in years but I was very unimpressed.
Very useful information... This one was at the top of my list. How is this different from a Fiskars (the heads of both are made by Fiskars)
Thanks for this... That is indeed a good method to avoid the edge geometry problem of a lighter head.
Just remember to twist the piece of wood you are splitting and not the axe, in case it bites in to the "chopping block" Sent fra min M2002J9G via Tapatalk
How about this?https://www.buckknives.com/product/108-compadre-froe/0108BRS1-B/
Setting up a base camp. I do short 2-3 day camps.
Very nice, but it's like buying your own coffin. I'd rather not have to use one and I'd certainly rather not spend money on it. Frankly I'd rather be thrown out into the river or let the birds have at me. This is a bit dear, as they say. I'd like to keep it under $50 USD.A hacking putty knife might do the trick... If they're still manufactured....
Do you walk to your base camp or drive?
For sake of argument (weight) I'll say it's a walk. It's a short walk with a lot of equipment. It's a half dozen friends that aren't particularly avid campers, so I'm afraid I might also be schlepping in bundles of firewood from a nearby farmstand.
Ahh, you beat me to it before I could post a Ray Mears video.Here it is anyway:Same with you! (technique shown from about 1:30 in)
I like the Fiskars X-7 hatchet for general uses including processing firewood, but a folding saw might be more useful for less weight. Personally, I prefer a machete to an axe but I camp in the Everglades. I wouldn't recommend it for hardwoods. If you really want to go minimalist, some people bushcraft with a wood chisel. I haven't tried it but I see the logic in it. It weighs the same as a small fixed blade knife. It only has about an inch of edge at the tip that has to be sharp, and you can split, scrape and pry with it.
