My mind is split between splitting tools 1465
Absolutely No Life Club Posts: 9,607
Re: My mind is split between splitting tools
« Reply #30 on: July 27, 2021, 04:49:48 PM »
Another vote for Fiskars axe(I have the Gerber Freescape 17" axe, which is very similar), I think they are pretty good deal, considering how well it performs, indestructible yet light handle and shock absorbing.  Basically all the weight is at the head, and the handle practically weight nothing.
Here is a comparison between Fiskars vs Wetterlings(many bushcrafters go to brand):
http://rockymountainbushcraft.blogspot.com/2011/12/review-new-fiskars-x7-hatchetbudget.html
The one thing I'd avoid are these flat headed type thing;
With basically no "wedge" shape to the head you'll have a very tough time splitting anything.  Sadly the Mora camp axe falls into this category IIRC.  Not tried one in years but I was very unimpressed.  :-\
I don't have this kind of axe, but my limited experience with smaller tomahawk(like the SOG fasthawk)does give me the impression that this kind of axe probably don't worth the weight.  Don't get me wrong, tomahawk are fun to 'play' with, throwing or processing kindling, but even for firewood size log, it could be difficult to split since the head does not have the geometry or the weight to 'split' the wood.
Thanks for sharing :tu:
Haven't seen those yet.
These videos are golden.
Since I am no expert in using my axe but I always love to use my hatchet/small axe for splitting wood for camp fire, I do often use the techniques in the second video for splitting and kindling.  By kneeling, instead of standing, I eliminate some of the risk missing and hitting my own shin/knee, especially when using a hatchet/smaller axe.  Btw, do wear proper eye protection if possible.
Global Moderator Absolute Zombie Club Posts: 26,431
« Reply #31 on: July 27, 2021, 06:03:52 PM »
I have and use a small hatchet.  I also have and use a roofers/carpenters hatchet.  They dont come with masks so you'll have to make one.  I also like to use wedges.  I've dealt with Eucalyptus that was a beast to split battoning.  Since I've gone with wedges either my small hatchet or combination hatchet and wedges made.
https://youtu.be/n08B0N61c4k
No Life Club Posts: 1,097 Brick Bradford of multitool universe
« Reply #32 on: July 27, 2021, 06:06:14 PM »
Dunno, but in your shoes I would take a simple  Fiskars camping axe. Light enough to carry, designed for camp duty.
Alternativly, a nice 'hawk for style, but for pure performance I'd go for the F.
by this axe I rule
Absolute Zombie Club Posts: 21,405 Oxygen and magnesium toghether?! OMg!
« Reply #33 on: August 03, 2021, 04:59:48 PM »
This. I thought about this method, but didn't look for a pic/video to show it. I think it's a great way to deal with the problem if you only have a small cutting tool with you.
 :cheers: :tu:
No Life Club Posts: 2,866
« Reply #34 on: August 04, 2021, 01:02:56 AM »
 :cheers: :tu:
 :iagree:  I assume that the kind of wood you use for the wedge matters though.
« Reply #35 on: August 04, 2021, 12:37:44 PM »
Felix mentions it should be a hard type of wood but I think if you use the same type of wood for the wedge as the wood you want to split, it'll work out just fine.
I once heard a friend saying the way to check if a ring had a diamant stone would be to scratch a piece of glass. Another one smiled and said "That's true, but remember: glass scratches glass, too.".
 :D :D
« Reply #36 on: August 08, 2021, 06:10:18 PM »
So the particular trip that prompted the question has come to pass.
You know what would have done the trick this time? A survival shovel.  :think:
There was actually a fair amount of wood to gather, a couple of fallen trees and a dead standing one.
Aside from splitting wood along the natural cracks (most of which I did by smacking it on the ground, and some by the stop-cut method) … what i needed to do was clean the ash out of the fire pit… lots of it.
 :dunno:
Admin Team Point Of No Return Posts: 34,090
« Reply #37 on: August 08, 2021, 07:37:54 PM »
As long as you had fun.  :D
Try not to be the person who blunders around and causes everyone else to get out the way.  Everyone else thinks you're a utter...
« Reply #38 on: August 08, 2021, 07:44:50 PM »
I've never tried one but perhaps a hori-hori might be of benefit?  A light garden trowel certainly has some uses.
« Reply #39 on: August 08, 2021, 07:58:57 PM »
That’s what I was thinking initially. A hori hori. But then I thought… go big or go home.  :tu:
« Reply #40 on: August 08, 2021, 10:02:40 PM »
Or you could go all "special forces" with a Cold Steel Spetnaz shovel. 8)  I don't know how practical it really is, but I recall them being fun for throwing at least.  :D
* Pics014THROW (1).jpg (Filesize: 55.94 KB)
« Reply #41 on: August 08, 2021, 10:16:42 PM »
I question I had in my mind was “would a bushcraft fixed blade do the trick?”
I don’t think it would have, honestly. Much of the wood was too heavy and too dead, and one if the guys had an Ontario fixed blade on him…. And it wasn’t quite right.
We ended up doing a fair amount with a hand-chain-saw too.
One of these over-engineered shovels would have worked, as would a mid sized camp axe.  I think a kukri would have done the job too.
No Life Club Posts: 2,139
« Reply #42 on: August 09, 2021, 06:10:28 AM »
 :dunno:
Sounds like a good time!
Something that is sometimes overlooked is that you don’t necessarily need perfect length wood for an outdoor fire pit.  I’ve dragged large branches and smallish dead trees over to the fire pit, started at one end and just fed them into the fire as they burned.
Absolutely No Life Club Posts: 8,483
« Reply #43 on: August 09, 2021, 12:13:32 PM »
Nor do you need a clean cut. The main reason I bring a saw is not for firewood but rather if I need to improvise something (eg walking stick).
« Reply #44 on: August 09, 2021, 06:20:29 PM »
Indeed. My fear was that I would only be able to get rounds that would need to be split to get proper coals to cook on. Not completely unfounded since the fire pit was left with unburnt rounds that didn’t turn into coals either. But ultimately it worked out.  :woohoo:
No Life Club Posts: 1,883
« Reply #45 on: September 05, 2021, 08:34:28 PM »
This is a good way to use a lighter hatchet to split larger wood.  Happens to be with a Fiskars X7.
https://www.youtube.com/watch?v=3TkP-K9GUVk
I spent quite a few years in the Adirondacks with my father and brother, chopping and stacking about 24 cord of wood per year. I started with them when I was 10, back in the very late 1970's.
This is more or less how I was taught to make kindling back before i was allowed to swing the maul onto logs to split them. I usually did as much as possible from the bark side, as one you are through the bark, it splits easier.
Looking back, it's amazing how much we worked
« Reply #46 on: September 05, 2021, 08:51:26 PM »
I think in that situation I would take a proper hatchet/tomahawk. It will be worth the weight.
Especially if y'all are relying on a fire for warmth and/or cooking - those thin things I would only take for a 'what if?' backup situation (and even then I wouldn't personally, I would rather take just a folding saw and a decent knife).
Right.
A hatchet is a hatchet and a knife is a knife. They dont do the same job, nor should they unless I'm stranded in the middle of nowhere and have only one of them with me.
You dont slice your chicken and vegetables with a hatchet (although I could with mine, as I sharpened the hell out of it) and you dont make firewood with your knife even if it is a nice fixed blade. Last think you want to do is dull your knife for no good reason, just to satisfy an urge to baton. By all means give it a whirl now and then, to practice in case of the apocalypse, but don't make it a habit. Right tool, right job.
This brings me to anothe place. You dont really use an axe to split logs. You use an axe to cut deeply into the cross section of a tree in order to fell it. Then to de-limb it. In the old days, to make the tree into logs. Most of that is done by chainsaw now. But you use a maul to actually split the logs. Its basically a big wedge on a handle. You might use steel wedges and use the back of the maul to drive them. But that's all heavier than what you are doing.
To that end, as has been pointed out by Gareth I believe, you want a more wedge shaped head rather than chisel edge.
I use an Estwing camp axe / Sportsman's axe which is really a hatchet, when camping. Between that and a bow saw or folding saw, the should do you fine
« Last Edit: September 05, 2021, 09:08:46 PM by ThundahBeagle »
« Reply #47 on: September 05, 2021, 08:54:31 PM »
I like that the Estwing is all one piece. No head to come loose and fly off. All steel. Leather wrapped handle. I'd still use the right gloves for better grip though
« Reply #48 on: September 05, 2021, 08:55:17 PM »
One of my favourite childhood memories is splitting kindling with my father at my great aunts' cottages.  Wood shed made out of corrugated steel and it always seemed like it was raining (superb sound).  I can't have been more than seven at the time! Terrifying in retrospect but I still managed to keep the standard issue of fingers and toes.  :D  I suspect my efforts were more enthusiastic than effective mind you.
« Reply #49 on: September 05, 2021, 09:07:22 PM »
Like the "yule log!"
January Goal: $300.00
Due Date: Jan 31
Total Receipts: $52.47
PayPal Fees: $3.73
Net Balance: $48.74
Below Goal: $251.26
16%
January Donations
SMF 2.0.18 | SMF © 2020, Simple Machines
Page created in 0.088 seconds with 72 queries.
© 2018 Defender Web & Tool
