The date code stamped inside my new charge+ tti is 11D -- I purchased this brand-new and it arrived sealed in retail box. I also have a newish surge stamped 1D -- this i received from leatherman (but not in retail packaging) under warranty replacement. Is Leatherman doing away with the mmyy format date stamp? If so, is there a simply formula to translate the new stamp to month/year?
I think those are part #'s and not date codes
oh wow, i had no idea. thanks for that info. I was just looking roughly in the area where i found a date code on my ST300are date-codes stamped at any other location?
Just like Steve C said, it should be by the can/bottle opener side, and the flat screwdriver side; maybe what you saw was the product code for the locks. The 2nd Gen. Wave and Wave + has them as shown, so probably the Charge too. First two pictures are date stamps (121317; 112217), and third one is the lock code(16D).
It should be on the inside of the sidewall of the handle in the middle.
You sir are a scholar and a gentleman :-) Indeed you are correct. I spotted a 1220 on the charge and a 0918 on the surge -- your pictures really helped.Thank you!
