I prefer belt to pocket carry, so I don't find my Herc to be a problem.
That's the problem in Australia.Carrying a knife on a belt is simply asking the cops to arrest you.A knife has to be carried in your pocket and as long as you don't flaunt it around, no one knows but you and anyone you help.Even a classic is illegal.Screwdrivers, nail files, I have seen an old guy bailed up in the airport for accidently carrying some nail clippers.I can just see it.80 year old guy holds the entire plane to ransom with a pair of nail clippers. But intellectual capacity is not why our tailor security or grubberment are selected for their jobs.
You can carry a Wave for that weight, and have better pliers, but as long as you don't need pliers, the Hercules is fine.
From my perspective, the Wave is a set of pliers with a knife and the Hercules is a knife with some small pliers.
Amici, After I saw this post, SO I had to add my two cents.. Personally when I do carry a SAK, I have leaned more and more to the "big guy" 111 mm models, specifically, either the Work Champ, or it's slightly lesser brother, the Hercules.. The biggest gripe most folks have indicated that they do not is because of their size and the weight. Sure there are either factory and or custom made sheaths for these available online which perform as intended, but still these are not for everyone.. Years ago, I found a solution to this conundrum, I stumbled across an EDC accruements website, and they happened to develop a way of carry for either 111 mm Vic's or likewise similar sized MT's comfortably and on a simple belt.. This is basically a large belt loop that is made of some sort of stretch retention material that once slipped over your trouser belt, can and will safely secure your 111mm Hercules on your persons once inserted into the loop with no issues. Hopefully the pics I have attached will better illustrate what I am trying to convey. Being an IT guy, I usually prefer to carry the Hercules when in the office for a host of reasons. The number one being is that it is very "sheeple" friendly.. When they see me produce this tool with its red or black scales, once they see the cross and shield I get responses of, "oh cool, is that a swiss army knife?" .. Where I respond with an "affirmative" and continue to get the task completed, without worries of complaints from the powers that be..The only downside is if you plan on allot of physical activity, you should use this option with a stiff belt, not one made out of a pliable material as the loop itself. In the beginning I used the loop with a USGI nylon BDU belt, and after a day of extreme physical activity, my Hercules actually wiggled itself out.. It didn't occur suddenly, but after engaging in some serious movements where the belt face would flex along with the loop, then ploop!! I do not blame the loop, but the activity and the belt.. But once I switched to a leather or some other stiff backed belt, It never occurred a second time.So don't rule the Hercules out as an EDC option.. There are solutions for comfortable carry out there, one just needs to be openminded to and determined in doing so, and be prepared to look. Cheers,Serge
The Work Champ....that one scares me.
Work Champ next to Work Champ XL!
