Tool hacks 455
Full Member Posts: 197
Tool hacks
« on: August 26, 2021, 03:49:39 PM »
Anybody have a good tool hacks they care to share?
Here's what I have to start off.
A couple short pieces of rubber hose can cover the jaws of a pair of pliers so they won't damage plated surfaces, when not in use they can be stored on the handles.
A quick release drill chuck for a 1/4" impact driver can be used as a file handle.  The same applies to a tap wrench.
A bolt with a 6mm head can be used as a 6mm allen key.  How do you hold the bolt?  tap wrench.  This of course applies to all sizes of bolts, granted you can fid a tap wrench that will hold them.
Locking pliers (vise grips) clamped around the shaft of a tired hood strut will keep a hood up.
Need a bolt to stay in a socket so you can thread it into a tight space you can't reach?  Wrap the bolt head with paper before putting it in the socket, the paper should hold it tight enough to start a thread.
Absolute Zombie Club Posts: 21,407 Oxygen and magnesium toghether?! OMg!
Re: Tool hacks
« Reply #1 on: August 26, 2021, 04:44:37 PM »
:worthless:
:popcorn: :popcorn:
Re: Tool hacks
« Reply #2 on: August 26, 2021, 11:14:38 PM »
Use your imagination.
Re: Tool hacks
« Reply #3 on: August 27, 2021, 04:17:41 PM »
I don't have one...
 :-[ :facepalm:
No Life Club Posts: 1,427
Re: Tool hacks
« Reply #4 on: August 27, 2021, 10:21:17 PM »
Got a hole that the wood screw doesn't grip any more: put a piece of a tooth pick in the hole first.
- Steve
January Goal: $300.00
Due Date: Jan 31
Total Receipts: $52.47
PayPal Fees: $3.73
Net Balance: $48.74
Below Goal: $251.26
16%
January Donations
SMF 2.0.18 | SMF © 2020, Simple Machines
Page created in 0.038 seconds with 41 queries.
© 2018 Defender Web & Tool
