can't you tighten it up?
Is it an up and down play?
It was LM's liner locks that actually put me off liner locking blades completely. The ones on my original Wave were simply awful and considering that it had been returned to warranty for new handles this was very disappointing.
Quote from: Benner on January 23, 2009, 06:55:48 PMIt was LM's liner locks that actually put me off liner locking blades completely. The ones on my original Wave were simply awful and considering that it had been returned to warranty for new handles this was very disappointing.The liner lock for the PE blade on my Wave is faulty too. It doesn't come out far enough to fully engage the back of the blade. The rest of them are fine though.
Quote from: max6166 on January 23, 2009, 08:44:22 PMThe liner lock for the PE blade on my Wave is faulty too. It doesn't come out far enough to fully engage the back of the blade. The rest of them are fine though.Just file an itsy bitsy from the back of the blade where it rests on the toolframe, that should do the trick without dissassembly of the tool.Use a piece of sandpaper wrapped around a thin piece of wood, or even better, the edge on a Sharpmaker stick.Whatever you do, don't overdo it.
When I got my Charge Ti as a gift brand new, the blade doesn't have any play at all its very solid but after 2 years of heavy use it has an up and down play very little no side to side play at all. My guess is its part of wear and tear, I don't have much experience with quality liner locks but in my opinion all liner lock after very prolonged and heavy use will have some kind of play.
Quote from: duckman1975 on April 10, 2009, 05:43:47 AMWhen I got my Charge Ti as a gift brand new, the blade doesn't have any play at all its very solid but after 2 years of heavy use it has an up and down play very little no side to side play at all. My guess is its part of wear and tear, I don't have much experience with quality liner locks but in my opinion all liner lock after very prolonged and heavy use will have some kind of play.Really, there should be no play whatsoever on a liner lock and I personally wouldn't use one that had any vertical play and get it fixed. I have never had any play on any liner locking blade apart from on an Original Wave.
Quote from: Benner on April 10, 2009, 11:28:10 AMQuote from: duckman1975 on April 10, 2009, 05:43:47 AMWhen I got my Charge Ti as a gift brand new, the blade doesn't have any play at all its very solid but after 2 years of heavy use it has an up and down play very little no side to side play at all. My guess is its part of wear and tear, I don't have much experience with quality liner locks but in my opinion all liner lock after very prolonged and heavy use will have some kind of play.Really, there should be no play whatsoever on a liner lock and I personally wouldn't use one that had any vertical play and get it fixed. I have never had any play on any liner locking blade apart from on an Original Wave.Does my Charge's play (its just a little) covered by its warranty?
Quote from: duckman1975 on April 10, 2009, 06:34:06 PMQuote from: Benner on April 10, 2009, 11:28:10 AMQuote from: duckman1975 on April 10, 2009, 05:43:47 AMWhen I got my Charge Ti as a gift brand new, the blade doesn't have any play at all its very solid but after 2 years of heavy use it has an up and down play very little no side to side play at all. My guess is its part of wear and tear, I don't have much experience with quality liner locks but in my opinion all liner lock after very prolonged and heavy use will have some kind of play.Really, there should be no play whatsoever on a liner lock and I personally wouldn't use one that had any vertical play and get it fixed. I have never had any play on any liner locking blade apart from on an Original Wave.Does my Charge's play (its just a little) covered by its warranty?I'd say so as I would classify that as a fault.Kwakster is the man that'll know.
Problem with these things is that most maintenance guys will see this as being anal about something that's really not that important (to them i must add,).Don't forget that for most of these guys multitool maintenance is just work, nothing else.However, in the parallel universe of multitool and knife aficionados it's a completely different ballgame, which is also the reason why i arranged for a few sets of maintenance tools to go to the right guys in our own community.In many cases they are the ones that can service your tool with the proper TLC (i hope this statement isn't out of bounds, )Personally i think that the top of the liner is worn, and it all depends on how much if changing the blade for a new one will help.A good maintence guy will check this first, and if this doesn't work, he'll need to exchange the complete leg and then rebuild all items in it.If i were you i would send it in, as in time it's only going to get worse.But make sure you attach a note to the tool on which you state the problem and it's importance to you.
I am a Quality Engineer for a seating company (not joking) I will offer my services to Leatherman
