Picked this up on Amazon for £21.99 the other day. Was looking for a Multiforce or similar clone. Only available as the Bibury for £54.99 ($75) - err no!
Main difference from the other Multiforce style clones is lack of a 1/4 bit driver, which is what I was really after. But you do get a 2 part small and medium philips which fold away together quite nicely - but would rather have the bit driver.
Blades are decently sharp, 1 stiffer than other and couldnt be opened 1 handed initially (slackened it off a bit). Scissors are good. Saw is OK. Diamond file is, hmmm. Used it to file some metal smooth and it already seems to be wearing off. Main issue is the pliers are wobbly. Ill have to try either the trick with a punch or using a set of grips to rotate the inner pivot to see if that helps tighten it up. Didn't come with a sheath.
All in all its not bad for what I paid. It has shown me I dont really like the Wave style, I much prefer the PST/Rebar style tools. I will be using this info going forward to get closer to what I need/like in a UK EDC. Current plan is to add scissors, diamond file, 1/4 bit driver to Rebar and disable the locking on any blades I keep in it to make it UK legal, whilst retaining locking 1/4 bit driver etc. Can then carry it and all the bits I need, in a relatively light format. Coming soon to a forum near you!
