December Rebar Challenge
Adam5 · 873 · 41183
Re: December Rebar Challenge
Reply #480 on: December 16, 2021, 07:42:22 PM
Day 16 of 30
BO Rebar today  :woohoo: used the pliers to pull some zip ties off and knife blade to cut some plastic  :tu:
us Offline Rich_SD
Reply #481 on: December 16, 2021, 08:23:05 PM
@Rich_SD I might try them og I can find any around here, thanks :cheers:
Blanton's is both rare and popular, so expect a ridiculous markup.  Woodford Reserve Double Oaked is MUCH easier to find, and it's just as good (albeit different) IMO.
Reply #482 on: December 16, 2021, 08:26:37 PM
Day 16
Reply #483 on: December 16, 2021, 08:37:46 PM
I love the Rebar blades!
nz Offline Pauldmmwc
Reply #484 on: December 16, 2021, 09:37:42 PM
Hello day 16.
Time for a new brew.  Rebar to remove the lid for a start. Now to wait 6 or 7 days for brewing to finish.
Semper Sitienti !!
bg Offline DavisNikolov
Reply #485 on: December 16, 2021, 09:44:56 PM
                                  Day 16
Summer vibes
pr Offline Juan el Boricua
Reply #486 on: December 16, 2021, 09:53:02 PM
Hello day 16.
Nice and intetesting endeavour; F/U please! :cheers: :drink:
se Offline RF52
Reply #487 on: December 16, 2021, 09:58:51 PM
Thanks, rare and expensive isn't really for me at the moment :cheers:
Reply #488 on: December 16, 2021, 10:11:20 PM
Day 16 of 30
Reply #489 on: December 16, 2021, 10:11:50 PM
Day 16
 :tu:   :like:
Reply #490 on: December 16, 2021, 10:12:31 PM
                                  Day 16
Summer
se Offline RF52
Reply #491 on: December 16, 2021, 10:12:54 PM
Day 16:
Cut of a bruised piece of an apple for a snack :tu:
Reply #492 on: December 16, 2021, 10:16:47 PM
Day 16
Reply #493 on: December 16, 2021, 10:35:12 PM
 :like: :tu:
us Offline Rich_SD
Reply #494 on: December 17, 2021, 01:53:45 AM
Hello day 16.
So this is a pre-made kit to brew beer at home?  Interesting!
us Offline Rich_SD
Reply #495 on: December 17, 2021, 01:57:03 AM
Day 16
Just some minor use today - I opened a couple packages, and I took another Christmas pic.
Reply #496 on: December 17, 2021, 02:01:19 AM
That's a great picture Rich!  :like:
us Offline Adam5
Reply #497 on: December 17, 2021, 03:21:25 AM
I wish that I had a tree full of Leatherman ornaments  :like:
us Offline Adam5
Reply #498 on: December 17, 2021, 03:37:14 AM
Day 16
Rebar saves the day!
I drilled these holes through the top of a wall above an electrical panel:
There is only 10" (25.4 cm) of space between the top of the wall and the floor above, so I had to use a short paddle (spade) bit fully inserted in my drill. With the bit fully inserted, it will not penetrate the top plate of the wood-framed wall. So, after drilling a hole the bit must be repositioned in the drill chuck to create enough length to penetrate the top plate. However, due to the construction of the bit it is easy to shear off the end of the shaft. You must adjust the clutch to reduce the amount of torque. I forgot to do this for the first hole.
 :doh:
The bit was stuck in the hole. However, with the help of the Rebar and by using the edge of the hole as a fulcrum, I was able to leverage the bit out of the hole. Though the end of the shaft has been sheared off, the bit is still useable and so is the hole.
us Offline Rich_SD
Reply #499 on: December 17, 2021, 04:06:03 AM
Thank you  :hatsoff:
ph Offline Zephon
Reply #500 on: December 17, 2021, 10:27:52 AM
Day 17
December 17
Was opening paint cans for touch up work. Was using the flat driver of the Rebar on me. Then I thought about the flat driver of the Wingman in that it felt ‘beefier’ as a pry tool.  I placed them side-by-side and well, both have their pros and cons. Anyway, I think the finger tab of the Wingman tools *might* need a *tiny* bit of trimming down to perfectly fit the Rebar.
Reply #501 on: December 17, 2021, 11:59:39 AM
Excellent Day 16 stuff all :woohoo: :like: and great start for us on Day 17, Zephon  :salute: :like: :like:
se Offline RF52
Reply #502 on: December 17, 2021, 12:44:29 PM
Day 17:
Opened a package :woohoo:
Reply #503 on: December 17, 2021, 01:02:13 PM
Great pic,  RF :like:
Reply #504 on: December 17, 2021, 01:04:24 PM
Day 17 of 30
Back with black again :D BOF carry today 8) :tu:
se Offline RF52
Reply #505 on: December 17, 2021, 01:20:47 PM
Thanks @Poncho65
And good looking BO Rebar :like:
Reply #506 on: December 17, 2021, 01:25:56 PM
Great pictures, RF and Poncho! :tu: :tu:
Day 17
First order of the day for the Rebar, get the punch pins unstuck; easy peasy!
« Last Edit: December 17, 2021, 01:47:28 PM by Juan el Boricua »
Reply #507 on: December 17, 2021, 05:00:25 PM
Thanks RF and Juan  :hatsoff:
Great use and pic,  Juan :like:
Reply #508 on: December 17, 2021, 05:04:05 PM
Thank you, Poncho. :hatsoff:
Day 17 (part 2)
Black on Black at noon.
Reply #509 on: December 17, 2021, 05:08:52 PM
Nice :dd: :drool: :like:
