A Rebar mod
us Offline Adam5
A Rebar mod
on: October 24, 2021, 06:14:37 PM
I decided to follow the lead of many others and try to make the awlsome Rebar even more awlsome. I removed the Phillips driver, the lanyard, and some washers in order to fit in a larger Surge bit holder (grinding required) and a pair of Multiforce scissors. I also replaced the awl and can opener with the Multiforce awl (previously modified) and the Multiforce can opener (which has a better wire stripping notch than the Rebar can opener). I also modified a couple of the straight drivers into a chisel and a package opener/scraper.
I chose to use Multiforce scissors because they are better than Wave scissors and because I had a pair I could use. However, they required a bit of grinding work on the plier head so that the Rebar could close properly:
Not ideal, but since I have committed to using the MT I decided to make it into one that would serve me well.
Re: A Rebar mod
Reply #1 on: October 24, 2021, 09:22:20 PM
That is a great bit of modding on the Rebar, Adam :salute: :tu: :like: :like:
  • He Who Has The Most Nuts, Wins!
Re: A Rebar mod
Reply #2 on: October 30, 2021, 07:59:18 PM
 :iagree: :tu:
00 Offline Dutch_Tooler
Re: A Rebar mod
Reply #3 on: October 30, 2021, 08:25:00 PM
 :iagree: too :like:
In fact, why not make an entry in the Showcase thread?
Cheers!
Dutch_Tooler
us Offline Adam5
Re: A Rebar mod
Reply #4 on: October 30, 2021, 10:12:23 PM
Okay D_T, I will  :salute:
Re: A Rebar mod
Reply #5 on: October 31, 2021, 10:54:07 AM
Seen the new entries, thanks Adam :salute:
Cheers!
Dutch_Tooler
July Goal: $300.00
Due Date: Jul 31
Total Receipts: $68.00
PayPal Fees: $3.74
Net Balance: $64.26
Below Goal: $235.74
21%
July Donations
